enginufuk
New Zaxcom small transmitter - ZMT
84 posts in this topic
Hi Glenn,
Which is Zaxcoms preffered DPA for your products-
4061
or
4063
Thanks
Simon
2 hours ago, Simon Hayes said:
Hi Glenn,
4061
or
4063
Thanks
Simon
I (coincidently) have just been working through this issue as I'm finally switching the majority of my COS 11s to DPA. Since I had no reference, I asked some heavy DPA users which model they had gone with and it sounded like 4061 was the general consensus, although the 4063 seemed to work just as well. However, when received the 4061s I was pretty surprised at the necessary gain/ tx noise floor with the trx la2. I then tried the 4060s that are labeled as high sensitivity and these seemed more appropriate for the large majority of dialogue recording. I used the 4060s on a shoot were it was requested and necessary to have the mics visible and pretty close to the mouth and even with loud projection (laughs, coughs, etc) they did not peak at the mic/tx stage. So, I'm curious if others are using the 4060s as well, or maybe the difference is too minor for many to care, or notice. Thoughts?
I also chose using 4060 (slims) with my TRXLAs, low sens was a no go hiss wise
4063 is what Zaxcom recommends, although I've also had good luck with 4060 slims.
There seems to be some misunderstanding about “red band” lavs.
A “red band” lav is one that is designed to be less sensitive than the standard, full-sensitivity version — typically, by about 10dB.
The DPA 4063 is a “red band” lav.  Other than the bias voltage, it has the same sensitivity and specs as the “red band” DPA 4061.
The 4063 requires a lower bias voltage, therefore making it more ideally suited for use with the lower voltage supplied by Zaxcom transmitters.
Some confusion enters because the 4063 uses a yellow tag to differentiate it from a 4061 that uses a red tag.  When people refer to a “red band” lav, they are addressing the fact that it is a lower sensitivity mic, and not simply geeking out about the color of a label.
Maybe this will help a bit:
  mic            sensitivity
DPA 4060   20 mV/Pa; -34 dB re. 1 V/Pa
DPA 4061    6 mV/Pa; -44 dB re. 1 V/Pa
DPA 4063    6 mV/Pa; -44 dB re. 1 V/Pa
DPA 4062    1 mV/Pa; -60 dB re. 1 V/Pa
If a lav has lower sensitivity, then it generates a lower output, therefore requiring more gain in the transmitter.  That additional gain also brings the noise level up along with the signal.
However, many of us are using 4063 lavs coupled with Zaxcom transmitters with great success, and noise hasn’t been an issue.
Further muddying this discussion is comparing the noise when using a 4063 to that when using a Sanken COS-11D.  The two mics have different sensitivities, making this an apples and oranges comparison.
And naturally:  “Your mileage may vary,” “plus tax and your old tire,” "some settling may occur," “void where prohibited by law,” and “results are typical but not guaranteed.”
On 4/11/2017 at 6:15 AM, VAS said:
I will throw out Lectrosonics from this test, because Lectrosonics use SmartNR.
First and second example; have high noise, even when microphone isn't plugged to transmitter.
1. Check the output type from the receiver (line or AES) and double check Nomad input setting. Remove everything (HPF, Limiters etc)
2. Check the output level from the receiver.
3. Check transmitter dynamics settings (set all parameters to low - you can't turn them off).
Thank you, VAS! #3, changing the dynamics settings did the trick! Now, as expected, the ZMT3 and DPA4063 make a beautiful sounding couple! Very happy! Thanks for everyone's suggestions.
Out of curiosity: Did the Zaxcom ZMT3 comes with the lowest dynamics settings from manufacturer?
What is now your dynamic setting ?
Not sure about the original settings. It's possible that they were and during my zest to go through all the menus I might have inadvertently changed them.
