elior Posted February 7, 2017 Report Share Posted February 7, 2017 Does anyone have experience with mke1 capsule? Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted February 7, 2017 Report Share Posted February 7, 2017 As with most lavs, if the wire/connection is broken at or close to the capsule, repair is usually not an option. Otherwise if still works ok.. shrink tubing. Quote Link to comment Share on other sites More sharing options...
elior Posted February 7, 2017 Author Report Share Posted February 7, 2017 I have 2 of them that broke in the same place I'll try to connect them and shrink tubing. thanks Rick Quote Link to comment Share on other sites More sharing options...
mikewest Posted May 19, 2017 Report Share Posted May 19, 2017 Yep,find the break, then fit heat-shrink on the longest end of the cable. Solder the wires together neatly with small amounts of solder not blobs. Half cover (from between the joints) with a small piece of split heat-shrink and secure with super glue and let dry Then slide the outer heat-shrink over the joint and carefully heat to shrink mike Quote Link to comment Share on other sites More sharing options...
