MartinTheMixer Posted February 11, 2017 Report Share Posted February 11, 2017 Hello all, I have a noise I can't figure out. I first noticed it when I bumped my boom. It is with a condenser mic. It makes a "crunch,hiss noise". The sound noise only happens if you bump the boom, or if you take it off the boom, and bump it in your hand, same thing. I am really not familiar with the whole humidity noise problem, something I've never had to deal with. I have switched mixers, cables and mics, and it is still there. The noise probably lasts for 600 milliseconds. Any ideas? Sincerely, Martin Quote Link to comment Share on other sites More sharing options...
Whit Norris Posted February 11, 2017 Report Share Posted February 11, 2017 What pole are you using and what mic are you using? Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted February 11, 2017 Author Report Share Posted February 11, 2017 Hi Whit, thanks for your response. It doesn't matter whether it's on the pole or not and I think it's going to be a humidity issue, the problem originally started with a DPA 4017c, I also tried and Octava Mic, it does the same thing but the duration and pitch of the sound is a little different. Since the original post I tried a Sennheiser e945 lead singer mic, as I call it. It does NOT have that same problem and I also tried one of my Sanken Cubs and it does Not have the same problem. So, DPA Mic has that problem, Octava Mic has that problem, both have of course similar, but much different quality of build. Picture if you held the mic in your hand, and shake it on the downward shake as soon as it comes to a stop in your hand you here that noise. So I guess it's fair to say it doesn't come from moving the mic but rather the deceleration of that Mic. Sincerely, Martin P.S. Is there some test to positively figure out if it's humidity? Quote Link to comment Share on other sites More sharing options...
Mobilemike Posted February 11, 2017 Report Share Posted February 11, 2017 You could try the "breath test" (gently). From Gearslutz: "What you should try is the "humidity test" or "breath test" to see if their is enough dirt on the capsule to get it to collapse. You don't want to spit on the capsule but you want to speak into without a pop filter and breath on it a bit to get a very tiny amount of moisture on the capsule. If the capsule is in bad shape the moisture from your breath will trigger conductivity across the dirt and this will show up as horrible loud thundering or crackling and the signal will cut out. Now, the breath test may also cause a good capsule to shut off for a second or two as well, but you won't hear the horrible noises a bad capsule will make when its shutting off and coming back on again."(jmikeperkins - 22nd December 2009, 08:49 PM) -Mike Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted February 11, 2017 Author Report Share Posted February 11, 2017 Mike, Thanks. I'm having that situation with two mics. The One mic is new to me the other is not. I don't understand what's shaking it is doing, the mic works absolutely beautiful as long as you don't move it. Matter fact both mics do. I'm tired and I might be missing something obvious here. Sincerely, Martin Quote Link to comment Share on other sites More sharing options...
cineli Posted February 11, 2017 Report Share Posted February 11, 2017 Martin, did you check out the very low frequency influence ? With bumps or simple movements, many microphones like the DPA 4017C generates these low rumbles that can affect different kinds of electronic circuits or even transmitters. In what equipment do you plug your mikes ? I would personally try a high slope filter like the Schoeps LC60 (or equivalent) between the mike and anything else ! Just to say.... Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted February 11, 2017 Author Report Share Posted February 11, 2017 Cineli, this is a crunch and then hiss sound. I'm plugging it into Nomads. I need to figure out how to get it into a computer and upload it, that's not really handy right now. Let me figure out how to do that. It's a little crackling sound, then, shhhhhhh sound. I think that's accurate, and it's on 2 different mics. I'm baffled. I think my inexperience with humidity problems is at play here. Maybe? Sincerely, Martin Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted February 11, 2017 Report Share Posted February 11, 2017 Does this noise issue persist when you plug those mics into another system, like a mixer or other recorder? Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted February 11, 2017 Author Report Share Posted February 11, 2017 Philip, Both Nomads, with several different cables all have same problem. The 2 different mics just make slightly different noises. Thank you. Sincerely, Martin Quote Link to comment Share on other sites More sharing options...
cineli Posted February 11, 2017 Report Share Posted February 11, 2017 Martin, I totally understand that it is not a rumble noise, but you are speaking about a noise that occurs with two different mikes when you bump the body. This can be a case where the very high amplitude of the rumble can affect preamps, limiters, transmitters, etc... Let me join Philip's answer: does it occur with other systems ? any kind ? Quote Link to comment Share on other sites More sharing options...
ramallo Posted February 11, 2017 Report Share Posted February 11, 2017 I never have a humidity problem with any of my 4017, also working in the jungle (With a Nomad) Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted February 11, 2017 Author Report Share Posted February 11, 2017 Cineli, When you say does it occur with other systems you mean what exactly? And I don't really think it's so much a matter of when you bump the mic, it's when the mic comes to a halt after being bumped, the deceleration. I believe that's an accurate description. Someone tell me how humidity plays out and what that sounds like? When you get a mic thats too humid does it crackle just sitting still? Sincerely, Martin 1 minute ago, ramallo said: I never have a humidity problem with any of my 4017, also working in the jungle (With a Nomad) Ramallo, Thanks. I am perplexed. And I don't find myself there often. Sincerely, Martin Quote Link to comment Share on other sites More sharing options...
ramallo Posted February 11, 2017 Report Share Posted February 11, 2017 Can you upload a recording with the noise? Quote Link to comment Share on other sites More sharing options...
r.paterson Posted February 11, 2017 Report Share Posted February 11, 2017 I had this on Maxx..is the hpf set to off or low setting , setting hpf to 90-100hz cured it....could be something similardit was LF distorting the a-d on input channel...richard Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted February 11, 2017 Author Report Share Posted February 11, 2017 R. , It is a different sound with high pass on at 90 vs. Off. Interesting. Ok, I am going to try to upload in a few mimutes. Sincerely, Martin Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted February 11, 2017 Author Report Share Posted February 11, 2017 With90hzHP.mp3 DPAMicNoiseNOHPFILTER.mp3 1 hour ago, r.paterson said: I had this on Maxx..is the hpf set to off or low setting , setting hpf to 90-100hz cured it....could be something similardit was LF distorting the a-d on input channel...richard 1 hour ago, ramallo said: Can you upload a recording with the noise? 1 hour ago, cineli said: Martin, I totally understand that it is not a rumble noise, but you are speaking about a noise that occurs with two different mikes when you bump the body. This can be a case where the very high amplitude of the rumble can affect preamps, limiters, transmitters, etc... Let me join Philip's answer: does it occur with other systems ? any kind ? 2 hours ago, Philip Perkins said: Does this noise issue persist when you plug those mics into another system, like a mixer or other recorder? 4 hours ago, Whit Norris said: What pole are you using and what mic are you using? Hi All and thanks for the help.The recordings I just uploaded are with 90 HZ HP turned on and turned off. I am taking the pole and swinging it really hard, then snatching it to a stop. The noise you hear is from the sudden deceleration. I have never heard this before. Sincerely, Martin Quote Link to comment Share on other sites More sharing options...
cineli Posted February 11, 2017 Report Share Posted February 11, 2017 Martin, what I can hear on your recordings let me definitely think about a pb related to low rumbles. I don't know so much about the Nomad but I wouldn't be surprised if the HP filters (low slope ??) may be far away after the input in the audio chain. The very first stage may be affected by these rumbles. You need to try with a high slope filter between the 4017C and the Nomad input (Schoeps LC60). The other way would be to try with a B preamp that integrates a hidden 50Hz +18dB/oct (not speaking about the ring filters). If possible you can also try with the new MiniCMIT which integrates a fantastic +24dB/oct 70Hz. Good luck ! Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted February 11, 2017 Author Report Share Posted February 11, 2017 Cineli, I just don't understand why I've never heard any of this before. And I don't understand why it's doing it on to 2 mics. The problem happens from sudden deceleration, I think. Your Nomad theory slope theory can only fit if Howy changed something in the Nomad. What are the theories why the handheld mic and the Cub don't experience that problem? Sincerely, Martin Quote Link to comment Share on other sites More sharing options...
al mcguire Posted February 12, 2017 Report Share Posted February 12, 2017 Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted February 12, 2017 Author Report Share Posted February 12, 2017 2 hours ago, al mcguire said: AL, we are looking at what? Sincerely, Martin Quote Link to comment Share on other sites More sharing options...
Constantin Posted February 12, 2017 Report Share Posted February 12, 2017 AL, we are looking at what? Sincerely, Martin That's your files. Look at the header Quote Link to comment Share on other sites More sharing options...
cineli Posted February 12, 2017 Report Share Posted February 12, 2017 Martin, all I can say is: what I hear and know let me think about a hard rumble issue, but maybe I'm wrong of course. The 4017C is well known to provide a high level of rumble that needs to be filtered. About Nomad, I had a look at characteristics (documentation) and I only found values of fcy cutoff but no indication of slope. It's also very difficult to know if filters are close to inputs or far away on the chain. On my opinion, most robust microphone filters are very close to inputs, analog and high slope. A handheld mike doesn't have that high rumble level. What do you call the "Cub" ? Sanken one ? The CUB-01 has a real filtering below 100Hz. Another explanation could be the input impedance of the Nomad: around 1kohms which can be considered a bit low for some microphones in front of hard signals (rumbles). In fact I would be interested to know how your 4017+Nomad would behave with the B preamp. Or 4017C + LC60 + Nomad, or ???MiniCMIT ! Good luck in your investigations ! Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted February 12, 2017 Report Share Posted February 12, 2017 It does sound like momentary overloading caused by LF rumble. The bit of static hiss you are hearing may possibly be the higher noise floor of the 2nd ADC in the Nomad. It's rare that I can ever hear that in the Nomad, but it used to be i big problem for me in the TRX742. Howy adjusted the timing a while back which made it much better. What happens if you replace the Nomad with another non neverclip mixer? Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted February 12, 2017 Author Report Share Posted February 12, 2017 2 hours ago, Constantin said: That's your files. Look at the header OK, sure. So, what are we looking at? What is the purpose? Sincerely, Martin 2 hours ago, cineli said: Martin, all I can say is: what I hear and know let me think about a hard rumble issue, but maybe I'm wrong of course. The 4017C is well known to provide a high level of rumble that needs to be filtered. About Nomad, I had a look at characteristics (documentation) and I only found values of fcy cutoff but no indication of slope. It's also very difficult to know if filters are close to inputs or far away on the chain. On my opinion, most robust microphone filters are very close to inputs, analog and high slope. A handheld mike doesn't have that high rumble level. What do you call the "Cub" ? Sanken one ? The CUB-01 has a real filtering below 100Hz. Another explanation could be the input impedance of the Nomad: around 1kohms which can be considered a bit low for some microphones in front of hard signals (rumbles). In fact I would be interested to know how your 4017+Nomad would behave with the B preamp. Or 4017C + LC60 + Nomad, or ???MiniCMIT ! Good luck in your investigations ! Cineli, I wondered the same thing about hooking up the B preamp. Last night , noise became much worse with it just sitting there you could hear the ocean roll loud. I should have recorded this, but I didn't because I was frustrated and just called it quits. That was with it just sitting still. When you say the handheld mic doesn't have that high rumble level, what do you mean? Why not? Thanks a bunch, Sincerely, Martin Quote Link to comment Share on other sites More sharing options...
cineli Posted February 12, 2017 Report Share Posted February 12, 2017 Martin, maybe Wandering Ear gives the exact reason (I don't know) but he's also convinced that rumbles may affect something in the input section. Generally, handheld microphones are compensated for proximity effect, so it naturally filters low frequencies...a lot. Pressure microphones (omnidirectional) also have a much lower sensitivity to low frequency rumbles. 4017C (or 4018, 4011) gives a lot of rumbles, but other well-known "pressure-gradient" mikes are sooo sensitive (CCM8, MKH8040/50) If you happen to make a test with B preamp or even C preamp + LC60, tell me about the result ! Philippe Quote Link to comment Share on other sites More sharing options...
