Nomad Zaxnet Frequency Change
Mosdeaf
I'm using a Nomad and changing frequencies on TRXLA2.5 units.
I've been accessing it through the ZNET button on the face. Once in the ZNET screen I change the freq using the menu button. It takes me a time consuming amount of twists to get from 550 to 600.
Is there a quicker way?
I apologize if this is redundant but I cannot find it in the manual or in a JW search.
Hello, Jack was close, you can use Nomad keys on face to enter zaxnet frequency in zaxnet menu. When I read that, it sounded good to me. I think it takes less than 10 seconds to go from one end of the frequency range to the other end of the frequency range. Sometimes 10 seconds seems like a long time. I don't use the function of entering numbers via the front faceplate, but I believe there are other numbers you can enter via this method.
Sincerely, Martin
