Sign in to follow this
Followers 0
Donald Kauffman
DPA 4060 wireless
17 posts in this topic
Hi Guys
Apologies if this is a noob question but I'm going to be using a wireless system for the first time (rental). I own 2 DPA4060s and I would really like to use them wirelessly. But I'm wondering if there is another way to connect them to a wireless system without having to spend 172 Euro just on the 2 DPA mini-jack adapters? Would I be asking for trouble by using a cheap XLR to mini jack adapter instead?
Thanks in advance
The end of lavaliers is microdot or XLR connector?
There are off brand (YPA) adapters for quite cheap on eBay. They work fine. But I would still recommend the dpa ones just for the ease of mind. They would work in the mean time though.
Thanks Jordan. They might be the ones to go for. Cheers
Donald, if you are still on this thread, I've worked with the YPAs, but they have let me down in critical situations:  the tiny thread for the microdot connectors was not long enough to make for a sturdy connection.  DAP adapters @ triple price sport one winding more, which makes for a reliable connection !
Resulted in ugly dropouts with some actor's movements. It took me several incidents of not knowing what caused the bumps and dropouts until I found it was the connector that was critical on the ankle when it came to skintight pants or on the back with a little sweat and tight clothes. I was using the Lectro-TA5 variant and this happened in 2014, so maybe YPA has already improved the design.
I have some of the YPA adapters for getting Lectro connectored mics into Shure wireless and vice versa as well as Lectro into a mini-jack Tascam DR10.  They are ok, but only ok, and I had some that were intermittent right out of the box.  If you go that way buy multiples, thus--they ship directly from China so the transport takes some time.  If I had DPA mics I'd for sure stick with their adapters even if they are more expensive.
I also got a YPA (TA5 to Sennheiser locking mini) that was snap-crackle-pop right out of the box.
If anyone knows how to open these up, please let us know how, I would like to try re-soldering mine.
Just in case you're still considering this: it won't work. The XLR MicroDot adapter needs phantom power. So all the adapters VAS linked to are unsuitable.
I didn't know that. Thank you Constantin!
OK good to know. Thanks. And thanks for the info on the YPAs, doesn't sound worth it at all. Has anyone tried these...http://www.ebay.com/itm/DPA-MICRODOT-MICROPHONE-ADAPTER-CONVERTER-TO-SENNHEISER-3-5mm-LOCKING-JACK-PLUG-/280709486205#shpCntId
Actually I checked those guys out and they don't seem particularly trustworthy
If you are not quite shure how often you are going to use your DPAs wirelessly, it is perhaps just easier for the moment to get your rental wireless including suitable lavs. So you don't have to spend that much for some adapters, that just get dusty after the shoot.
If you WANT to buy the right adapters, I absolutely recommend the ones from DPA. They are very high quality built and it could happen that you have enough struggle with a lav itself  (i.e. if you're hiding it), so a well built adapter would be one less thing to worry about.
Thanks yeah you see I'm mainly a post guy so it would only be the odd occasion I'd use them. So your rental suggestion is probably a good shout. Would just have been nice to be able to use the dpas from time to time
Followers 0
