Sign in to follow this
giraffe
Prepping a room
giraffe
Well, I played around recording my fiancée and mom a little today, and I can't remember who said it but they were right, I hear the room more then I expected.
(That same person also said a number of other things I found to be correct in my short test, but that's for another time)
So what's sop for prepping a room? Just hang blankets anywhere you can (that can't be seen obviously)
Or....
Well, or what do you do?
Like gaff tape mic stands and blankets?
Thanks!
There is no SOP, unless you are fortunate enough to have pre-shoot scouting, unlimited time/budget, available materials and an accommodating lighting and other departments, you're very fortunate. It does not happen in my world though.
There is an art, somewhat informed by an understanding of science/physics/acoustics, to treating a room. If all you have to work with are furniture pads ("sound blankets" when in our hands), you can devise any method you want to hang them in places where they will not be seen by camera and do not interfere with lighting. There should always be a space between the pad and the wall and be aware that ANY furniture-type pad will generally only help with high frequencies. Bottom line, almost anything you put in a room may help --- I have gotten significant benefit from just placing a pile of pads in a corner. You just have to experiment.
Quick helper rule of thumb--if you only have a limited amount of absorptive material, don't use it on opposing surfaces.  Treat two walls that meet, the floor but not the ceiling (or vice versa).  Usually your options for getting "stuff" near talent are severely limited by the shot, props etc.  Being able to "soften" a hard floor is often a good idea, esp if you have furni pads that are black/white.  (It's considered uncool to try and get a pad with any color in it at all (like the ubiquitous blue mover's pads) near talent, or near anything white that's in the shot...)  Beyond this you do whatever you can get away with.   Rented theatrical curtains, 12x or 20x blacks hung from speedrail or a piece of a frame on a high-roller stand, carpet for the floor, and on to more heroic methods, like filling an echoey dome over a set with helium balloons, coating a noisy roof that's being rained on with hogs-hair, and so on.    An illustration of what Jeff said re: how much a little absorption can help: notice the diff in the sound of your bathroom when you take all the towels out!
giraffe
Buy many tons of hogs hair, check!
Somebody get shavin' them hogs!
-Mike
If you're really serious about learning this stuff, spend more time doing.  What did you discover when you tried different methods and materials in different rooms, deployed in different ways? Talking about sound is one thing; listening to sound is yet another.
Train your brain by learning to listen.  It takes years to be really good at it, but the more time spent in actual practice, the better those years will serve you.
Bash
When you put your furniture pads/sound blankets up, be aware of what the rest of the setups are for the current scene, I'd which walls will be safe on which setups. It can help a lot to enable you to have a similar amount of blankies up for each setup, even if they are on different walls each time.
