mojofunkster
What are your Zaxcom compressor settings?
14 posts in this topic
I'm pretty new to zaxcom and I'm curious what settings people recommend for the Dynamics settings.
Thanks,
SW
Sent from my Nexus 6P using Tapatalk
Zaxcom makes a wide variety of gear and your question is very broad, so my best advise would be: use the setting that sounds best for your given application.
Sorry if that sounds snarky, but I have no idea what you are trying to do or what other gear is in the chain.
Sorry for being vague, I'm using the trxla3.5's. I've been using the default settings, but just wanted to know what everyone else was using.
As far as settings, what you're recording is more important than the gear you're using.
But, since you're being general, I will be too...
Generally speaking, you don't want to actually use compression for location mixing.  When in doubt; leave it out -- then adjust your levels so you never hit the digital brick wall.
I work a variety of different gigs, and for the most part, I set the transmitter's compression as only a safety at the far reaches of my dynamic range.  That basically means I set it so it is hardly ever in play -- except that it might allow me a couple of extra dBs and a smoother limit on a rare peak or two.
>When in doubt; leave it out <
A good rule in general
Most of us (I would assume) just use a peak limiter (compressor with a high ratio and threshold) to catch occasional peaks. That said, in audio post and music, I don't think I've ever used the exact same compressor settings twice. Depends on the track.
A 1db difference between the loudest & softest parts sitting @ -.05 db on the meter seems to be reasonable.
LOL!
Metallica would agree.
Thanks,
SW
Fair enough question, was about to ask it myself. If in doubt leave it out doesn't really work with the latest series of zax trx's as the "dynamics" settings also relate to how never clip works also so would be interesting to see if many out there are using custom settings or just run with the factory defaults etc.
C.
Rather than dismiss a voice of experience because it doesn't fit some preconceived notion of what you've decided should be an appropriate answer, perhaps you'd be well served to learn how it applies.
In this case it applies directly to Neverclip systems -- which is what I use a good percentage of the time.
Neverclip was developed in no small part in order to avoid the need for the nonlinearity of compression.
for Neverclip to work you DO NEED compressor working! That's from Howy. Otherwise you dont overload your mic pres but the TRX  would not record / transmit the hot signal.
So I have mine at -3dB, ratio 20:1, fast&fast.
I don't know if this is directly applicable to Zaxcom compressors but I recall having a conversation with Bruce Bisenz about limiter settings for production audio. We were setting up the limiters in a Cooper mixer and he recommended (if I recall correctly) a medium-slow attack with release "as fast as possible."
David
Which goes along with what I'm saying.
Yes, in a Zaxcom Neverclip transmitter, the compressor is always on.  That seems slightly counter-intuitive as, like I mentioned above, Neverclip was developed with the intent to avoid the need for the nonlinearity (i.e. signal alteration, or distortion) of compression.  But, having it in the circuit doesn't mean you have to, or even should, actually compress your signal.
Note that Matthias' settings only kick in as he approaches digital zero, which is easily avoided with Neverclip.
What often leads to confusion, is that while Neverclip does extend the dynamic range, it does not do so by allowing a signal to go beyond digital zero -- the digital brick wall.  A brick wall is a brick wall and if they hit it, your ones and zeros shatter into tiny unrecognizable fragments of broken bits.
In simple terms, Neverclip extends the dynamic range downward.  That means to take advantage of it, you operate with a nominal level further below digital zero.  This, then, is how you can have a compressor in the circuit and never -- or, at least, only rarely, actually use any compression, as you can adjust it to only kick in well beyond the signal range you normally need.
My settings are different from Matthias' but they still accomplish the same result.  To do so, one simply avoids pushing the signal hard enough that any compression kicks in -- except, perhaps, only in the most extreme, and rare, cases.
