Rathergy Posted April 11, 2017 Report Share Posted April 11, 2017 This is my issue with the XLR box. It simply stopped working out of nowhere. The audio bar on the video recorder doesn't fluctuate and the 48V of power doesn't light up when I speak through the mic. So I think something is wrong with the box but have no proof. I have two mics and they don't flash when hooked up and talking. They should when someone speaks into a mic. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted April 11, 2017 Report Share Posted April 11, 2017 It looks like the Left channel mic/line switch is in the LINE position. Try flipping it to MIC? Are you sure your power is good, ie sufficient voltage ie good batteries? Quote Link to comment Share on other sites More sharing options...
Rathergy Posted April 11, 2017 Author Report Share Posted April 11, 2017 I'll go and test it out. I tried everything. Any idea as to why the 48V lights aren't flickering whatsoever? I used to use a 8.4V battery for the longest time with no problems and then tried a 9V after the setup stopped working. The manual recommended a 9V. The original battery was rechargeable, too. Final photo: https://www.dropbox.com/s/xnbh1wiiiks2s98/20170410_021504.jpg?dl=0 Quote Link to comment Share on other sites More sharing options...
Rathergy Posted April 11, 2017 Author Report Share Posted April 11, 2017 All that happens is I get a wall of "white noise". No human sounds. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted April 11, 2017 Report Share Posted April 11, 2017 Check your batteries! Try a known-new+good one! Quote Link to comment Share on other sites More sharing options...
