Sign in to follow this
MarkC
ADVICE: Nagra 4.2 Mixer connections
MarkC
Hello Everyone,
I am seeking advice on making a dual purpose cable to connect to the Nagra 4.2 7 pin mixer connector.
I have a remote start/stop box and a playback preamplifier output cable. I want to connect both to the mixer connection at the same time.
Correct if I am wrong please. If I had a single 7 pin tuchel and connected the remote on/off switch to pins 2 6 7 and a playback cable connected to 5 7 that then went out to two separate female 7 pin tuchels could I run both stop/start and receive an output signal simultaneously?
I would be very grateful for your advice.
Thank you
MarkC
mikewest
Hi
Do not " connect the remote on/off switch to pins 2 6 7 "
Stop/start switch you connect to 6 & 2
Yes you can take an audio out feed from 3 (signal) and 7 (ground)
mike
MarkC
FWIW I made a three way connector cable to operate output, input and start stop today and it works flawlessly. Thanks Mike, your advice was exactly what I needed.
Thanks everyone
