Sign in to follow this
Matt
Ambient Eumel Noise
I was using an Eumel with a COS-11 lav hardwired to my 788 yesterday and noticed it was very hissy compared to my other Eumels. Does anyone know how to fix this? I'm thinking a grounding issue with the P48 inside the Eumel. Does anyone know how to disassemble one? It's glued together pretty tightly.
Hi, we use special tools and heat. But I don't think you will find anything serviceable from your end inside, and I doubt even more that's causing the noise. Do you have other lavs to compare it with? Is that a newer one that's hissy and the older ones don't? We haven't made changes since quite a while.
Yes. It is strange. I changed it out for another Eumel I had with the exact same lavalier and XLR cable on the same channel of my 788T supplying phantom. The noise went away. What did you change when you made the newer model? Perhaps I can look inside to see if something is different.
