Matthias Richter
new plugOn TRX from Zaxcom
my ZMT3 48V lets me adust the phantom power to 45V (five) max not 48V. Is that a typo within the ZMT or ...?
from the manual:
This menu is where the phantom power is turned on and adjusted from. The ZMT3 Phantom has 5 user selectable power options:
OFF, 12V Phantom, 24V Phantom, 36V Phantom or 48V Phantom
On 6/20/2017 at 4:34 PM, fieldmixer said:
Makes you wonder if the zaxnet tx componts can fit in here with everything else, why oh why is it not in maxx!! Arg!!emoji23.png
Cost cutting  / product differentiating :mellow:
Oh well, how long until the Maxx v2.0? (or whatever they call the next model, probably something different than that, which will have this?)
Yes, about 2.5 hours with the ZMT phantom transmitter, which is about an hour less than the plugon. Regarding the 45V phantom question, the AES spec for 48V phantom is +/- 4 volts.
16 hours ago, Matthias Richter said:
btw runtime with a Schoeps CMIT5U / 50mW: 3hours sharp.
So you wanna change after 2.5hours to be safe. Miles away from 5 hours ...
Curious what batteries you guys are using.
I doubted what I had perceived as run time, so retested today using my oldest Fujifilm NP50 batteries that I brought when ZMT body pack first came out.
I got 3hr 35min until low battery warning and a further 10min until complete battery failure. 50mw 45v Mini CMIT.
With a regular CMIT run time until warning was roughly 10min shorter. I missed when the warning appeared. Same settings.
The shorter run time on the CMIT is probably just a battery thing (honestly haven't checked if there is a difference in power consumption between the CMIT and Mini).
Agreed it certainly ain't the 5hrs advertised. I guess 5hr is based on 25mw 12v, but that isn't where most of us work.
According to their specs:
The CMIT5 pulls 4.4ma at 48v.
The mini-CMIT pulls 2.3ma at 48v.
The CMIT5 is listed as only a 48v. mic, whereas, the mini is designed to operate on 12-48v.  Note, however, that the max SPL of the mini is 15dB less at 12v. than at 48.
I'm very happy getting now around 5h30min (non stop ) with a MKH8060 (P48 - 3.3mAh)  with the TRX 742 (50mw)
with the  Lmount battery mod :-)
3 hours ago, Glen Deakin said:
Lmount battery mod.  That's pretty cool. Where did you get that mod done.
Need to contact Gene Martin at Audio Dept
28 minutes ago, Glen Deakin said:
Is there a power switch?   Or does it just come on when battery is inserted?
The second option (Battery insert on)
