cjh Posted May 30, 2017 Report Share Posted May 30, 2017 Hi, now inside with no wind machines but set has steam vents, these seem to me to be noisier than they need to be with each outlet being run from a separate small handbag type unit with a gun and trigger used to set level of output (via cable tie on the trigger so not very hi tech and adjustments always vary etc) Putting a small length of hose on the end of the gun nozzle gets the frequency and level of hiss down but I'm sure there must be quieter ways to create steam onset? we also get a lot of "spitting" on some of the rigs as vapour turns to water and runs back down the pipe. Any insight on other techniques much appreciated, losing CU dialogue to hissy steam vents, aarrrgh. Note these are not high pressure steam outlets, more the steam wafting out of drains kind of thing or being used to simulate small onset smoke fx without having to use smoke, food stall cookers etc. Thank you! Chris. Quote Link to comment Share on other sites More sharing options...
mikewest Posted May 31, 2017 Report Share Posted May 31, 2017 Hi Chris, Sadly cannot offer suggestions as I have not experienced this particular problem. I suggest you set up a meeting with SPFX supervisor and PM or Producer. As you would realise, this prompts awareness and stops you getting "blamed" Cheers mike Quote Link to comment Share on other sites More sharing options...
cjh Posted May 31, 2017 Author Report Share Posted May 31, 2017 hey mike, getting there and sfx do there best to help, it's a noisy gig! Quote Link to comment Share on other sites More sharing options...
