Sign in to follow this
chris_bollard
Transmitter SMA Connector
Thanks Mike, but I am looking for the type of connector that Lectro uses for their Transmitter antennas. The centre pin is solder and there is a compression rubber grommet that locks the cable in place.
Hi Chris. Sounds like you're describing the dielectric material present in 50ohm coax cable and SMA terminations. Any 50ohm SMA cable should suit your needs.
If you're after a replacement whip antenna, there are plenty online. Stick to 50ohms, trim it to the appropriate frequency and you'll be fine Mate.
Hi Chris, That's a custom connector made by us with the compression o ring. Call service for the part.
Best, Larryf
