JoelB Posted July 11, 2017 Report Share Posted July 11, 2017 Hi guys, hope you're all well. Has anyone had any luck powering a Zaxcom QRX100 from batteries? I made a battery cable - 2x9v batteries termination in the QRX DC plug. Works for about 20 minutes then doesn't work. I can't work out if the power is being drained from the 9Vs too quickly, or if it's a different problem. Would appreciate any insight - or product links that I could buy to make this work. Many thanks Quote Link to comment Share on other sites More sharing options...
Boomboom Posted July 12, 2017 Report Share Posted July 12, 2017 Quote Link to comment Share on other sites More sharing options...
glenn Posted July 12, 2017 Report Share Posted July 12, 2017 The QRX100 needs 12V at about 300ma. 9V can not do that for you. Use any 12V nominal battery that can supply enough current. Glenn Quote Link to comment Share on other sites More sharing options...
JoelB Posted July 14, 2017 Author Report Share Posted July 14, 2017 Thanks guys! Boomboom - that link to the already answered article was extremely helpful! Enjoy your weekends Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted July 17, 2017 Report Share Posted July 17, 2017 Two 9v. batteries in series could power it but their combined voltage may be a bit too high to be within safety margins. If they're connected in parallel, it'll perform just as you described. A choice that'll work fine is an 8 AA holder with the appropriate power plug. Quote Link to comment Share on other sites More sharing options...
