alenK
Can a Lectro R1A UHF IFB Receiver "listen in" on a SMQV to SRC camera hop?
Hello,
 I am wondering if the Lectrosonics R1A UHF IFB receivers can receive the same signal that may be sent from a SMQV transmitter to a SRc receiver "digital hybrid" wireless camera hop?
 It seems as if using this type of configuration, if it is possible, may on some occasions eliminate the need for one more transmitter cluttering up bandwidth.
 Thank you.
If you set the SMQV to IFB mode you can receive the signal but otherwise no. And IFB mode isn't as good as digital hybrid mode so you wouldn't want to use that to record your lav tracks through the SRc, but if they are just for hops then you can set the SRc to IFB mode as well as the SMQV and use all three
Thank you for explaining.
I just went and read the IFB T4 manual and see that even the "digital hybrid" IFB transmitters have to be run in IFB mode to work with the IFB receivers. Now it all makes sense.
Thank you.
The wide deviation transmitters can be turned down to narrow deviation to match the ifb units. The narrow if section in the ifb receiver (R1a) can't be "widened" to the digital hybrid modulation. So it's a one way street.
Best,
Larryf
You have to decide whether the quality of an IFB signal is is sufficient for camera in that instance. For me, since scratch/reference is the norm, I do this fairly often either by strapping an R1a to camera or renting a buddy's 411. Very convenient to only need 1x transmitter in the bag.
I would love to have a R1 format receiver that could receive a signal from one channel of my camera hop.  And I bet I'm not the only one...
Brent Calkin
Thanks for that link Peter.    The economic argument against a 400 mode R1 makes sense, although as a documentary recordist who only needs one unit for the director and maybe one for a field producer- I probably WOULD pay $1100 for a single IFB receiver channel, if it meant that I could leave the comteks at home.
Brent Calkin
M2R is awesome however the antenna's are a deal breaker for me.
I use my R1a to feed the judges inductive neckloops and earpieces on my regular show. They're tricky enough to hide sometimes even without antenna's.
Even for field producer IFB, antenna's are going to get in the way.
I'm pretty sure Lectro could make a 400 mode ifb that also could be switched to other existing  modes, LCD screen, lots of presets, IR with app to program etc as per my other post in other thread, WITHOUT an external antenna.
I'd buy a bunch, for sure.
