P48 to T-Power converter?
TommygunZA
2 questions if I may...
I have found this on second hand pages here in ZA
sennheiser mkh816t  about $150
I have an old 302 which can handle it I think being T-Power. I dont think my SD 633 will though. Do converters work, is there a 'trusted' brand to get a T-Power mic working on P48 gear?
 Secondly, Im a sucker for a bargain and love 2nd hand trawling. Is the MKH816t worth a shot at 816? At that price its almost, never mind the quality, look at that length. Im sure I can find a use for it one day....
Yes to all your questions.  The only real downside to an 816 is its weight.
Like the 416 -- a workhorse.
PSC makes a reasonably priced adapter barrel.  I like the older version of the barrel better, though -- metal rather than plastic -- a tad more weight, but less susceptible to hum (maybe they've switched back over the years -- it's been a long time since I bought one.)
A legendary mic.
Great thanks I've got a 406T which sounds great and would get a lot more use if it was P48, I'll investigate......
Further investigation - (forum insists on appending this to previous post rather than a new post?)
Looks promising thanks,
http://www.416tupgrade.com/416Tupgrade.com.html
mention of the 406T :)
  1. 4.I have other microphones that are T-powered. Will you upgrade them?
We also upgrade most Sennheiser 415, 435, 815 and 816T microphones. Please inquire about 406T mics.
I got a the local audio shop (Audio Services Canada in Toronto) to build a shortie cloth covered cable that has the T12 to P48 magic built into the XLR boot. Same as the barrel I imagine, but without the bulk. Cable runs from boom pole to inside of Rycote wind shield.
The PSC adapter has worked great for me. I use it on my 416T, which I had serviced a few years ago and functions like a new mic. I suggest sending the 816T back if it’s not functioning perfectly to Sennheiser and they’ll make it good as new for a reasonable sum.
Form factor obviously suffers if it’s on the barrel and it does add a little weight.
