new low cost radiomic
stefanosound
Senal is a "sister" company of B&H Photo & Video. Most of their stuff looks like low-cost knockoffs of established equipment. Maybe these wireless systems are fine; but I'd want to be REALLY convinced before I'd ever use these...Like by hearing reports from mixers I trust who've used that equipment on real jobs for a few months. I think it will be a long time until I hear such reports.
And then:
The.AWS-2000T.and.AWS-2000P.Transmitters.feature.two. output.level.settings:
•.  Lo (5 mW).is.ideal.when.the.transmitter.is.relatively. close.(150.feet.or.less).to.the.receiver..It.also.provides. the.transmitter.with.approximately.20%.more.. battery.runtime.
•.  Hi (30 MW).allows.the.microphone.to.cover.a.wider.area. and.more.range..This.setting.is.recommended.if.your. subject.is.moving.around.or.is.consistently.more.than. 200.feet.from.the.receiver...
Even if the TX had higher output , not for me. But if anyone here buys a set and can compare them to established system, let us know what you find.
30mW is fine for many applications. The Sennheiser G3 range (at least the 100/300 range) also only has 30mW and their range is pretty decent.
Sure, I can get some work done with 30mW. But when I need more, I don't want to have to switch systems.
Constantin and Christian, let us know what you think of your new Senal wireless. :-)
Its not always about RF power when talking about range. What helps allot with range is pre emphasis and companding settings. System designers tune these parameters to maximize signal to noise in the fm modulation and airwaves domain. This improves range and give us advertising number of 500f of range.
With something like this id be interested to see how it holds up to say a cooking show, with hard transients, fat sizzling, pots and pans chiming and wide dynamics.
Its one thing to have a pre emphasis and companding system and setting to maximise range but its another to have a setting to handle transient noise like cooking shows. For me being able to switch is key. Wisycom's ENR and ENC settings are ideal for lot of real world jobs.
Sorry if you got the impression that I wanted to buy these. Just pointing out that 30mW per se is not a problem with, for example, the very popular Sennheiser G3 range.
G3s are cheap but Sennheiser back them up pretty well--they are included on their freq charts, there are parts easily avail, and the package (when bought new) is pretty well thought out re: mounting especially.  They are also easy to get more of used or rental if you need them.  The Senals look cool, but like Jim I want to hear from some early adopters...
Ya, I agree. And I use them but again, not as a replacement for my Lectros. I could have quoted a better spec in my Senal diss.... I guess my point is I'm not looking for something not quite as good as a G3.
If they sold the transmitters/receivers separately, it might make a decent scratch audio system (nice that both the transmitters and receivers are switchable to mic/line inputs) although the antennas do look a bit bulky on the receiver.  Nice that they have detachable BNC antennas on the receiver at that price point though.
On 23.10.2017 at 1:09 PM, daniel said:
Really? Just how much of a human's voice is outside those numbers? And what advantage is there in recording those freqs?
d r
Well sharp "s" sounds in the human voice can reach up to 16kHz. Okay, it´s not much to be missed but you don´t capture the whole thing this way. Also I like the thought of having a little bit of high end frequency headroom to not technically limit what you record.
On 23.10.2017 at 3:14 PM, Christian Spaeth said:
So Zaxcom wireless is also not usable to you? ;-)
Okay, didn´t expect that...
I think I know what you mean by this, but just to point out the obvious: you always limit technically what you record.
3 hours ago, Patrick Tresch said:
In that subject Sonosax always fine tuned their electronic circuit to be able to record even the harmonic that exceed the human reach because they have an effect on the overall sound or when used in FX.
Which is a nice feature for a recorder that will get used for many things including speech and music but for a wireless lav mic worn by a speaker(?), so much has gone on before the signal reaches the recorder by way of optimising the signal for the technical limitations/demands of wireless audio that, the audio response quoted is acceptable (however good the recorder is after it), possibly more so than other details about the system.
  • 1 year later...
