Jim Rillie Posted January 9, 2018 Report Share Posted January 9, 2018 I have a bad PR-216 output cable at the mini phone connector, just wondering about wiring, because it is a sealed connector. The XLR end of the cable has resistors and a small capacitor siliconed in. Just wondering if replacing this connector is possible - would like to use a Neutrix right angle mini-phone. I'll also contact Comtek on this and spread the word when a response is received. Jim Rillie Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted January 9, 2018 Report Share Posted January 9, 2018 This sounds like you're talking about a Comtek input cable (for an M216 transmitter) which has a built-in filter. Comtek support can, indeed, shed more light on this and will even send you schematics of the cables. The PR216 (receiver) output is a mini TRS with the T & R wired out of phase. This is the shortcut method Comtek uses to make a mono output compatible for either a three connector or two conductor plug. When used with stereo headphones, many folks (I'm one of them) don't like this out-of-phase effect you get between ears and, therefore, wire my Comtek headphones with a two conductor (TS) plug. Quote Link to comment Share on other sites More sharing options...
Jim Rillie Posted January 9, 2018 Author Report Share Posted January 9, 2018 Hello John, Love the jet powered porta potty, or whatever it is. This cable is a Comtek output cable (with the same choke on the cable as the one you refer to) with a mini TRS connector at the receiver end, and a male XLR at the other end to feed a line input The Option 7 receiver puts out up to +15 dB according to the specs. Jim Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted January 9, 2018 Report Share Posted January 9, 2018 Didn't know they used the filtered cable on outputs, too. Anyway, contact Comtek support. I've found them quite friendly about supplying cable schematics. I have the schematics but they're somewhere at my studio so you're better off contacting Comtek as I'm away from there. Quote Link to comment Share on other sites More sharing options...
