MixPre 10T - Audio Interface Setup Into Logic - Music Tracking Operational Questions
Hi fellow MixPre 10T users,
Is anyone using their MixPre 10T as an interface into Logic, in full advanced mode?  Have you found a fluid workflow? I'm finding the manual lacking when it comes to using the 10T in a multitrack music recording session with a typical DAW.
I'm quite used to using the Apogee Maestro control software that controls my Duet, though only 2 channels. I gather that all the control of the MixPre 10T in USB interface mode is done strictly within the MixPre 10T machine itself? As someone already suggested, hopefully Sound Devices might come up with a software control panel.
Just trying to wrap my head around the signal flow when using the 10T as a multi-channel audio interface. If you have any workflow, settings tips or resources to share that would be most appreciated.  In the meantime, back to the manual and trial and error :-))
Thanks kindly.
