Ilari Sivil Posted April 5, 2018 Report Share Posted April 5, 2018 (edited) I'm looking at what could be a good deal on some 4061s that are hardwired to Sennheiser TRS, and I'd like to redo them in Senn/AudioLtd/Wisy/Lectro SSM-compatible 3-pin Lemo. From what I've researched a bit, one would need the right connector to get the right cable diameter for the strain relief to work properly. Any clues on the right connector and a European source? Edited April 5, 2018 by Ilari Sivil Dialed the wrong number for the DPA lavs I want. Quote Link to comment Share on other sites More sharing options...
Constantin Posted April 5, 2018 Report Share Posted April 5, 2018 4071? maybe this? https://m.thomann.de/de/lemo_3_poliger_stecker_nfstpro455.htm Quote Link to comment Share on other sites More sharing options...
Ilari Sivil Posted April 5, 2018 Author Report Share Posted April 5, 2018 9 minutes ago, Constantin said: 4071? In my morning grogginess, I accidentally went for the wrong number. I meant the 4061s. Editing now. 9 minutes ago, Constantin said: maybe this? https://m.thomann.de/de/lemo_3_poliger_stecker_nfstpro455.htm That should work, if the cable diameter is the same. Sennheiser's part catalog has two versions for their different lavs, probably due to the cable diameter. ( http://spares.sennheiser.co.uk/wireless-3000-5000-series/lemo-connectors ) I don't have Sennheiser lavs or DPA 4061s readily available, so it would be really nice if someone could check if they match. Quote Link to comment Share on other sites More sharing options...
