DHuard
Direct feed from mixer to camera
Question.... when I do a direct feed via a snake from the mixer to the camera, what is actually recorded to the camera ? Is it the mix or are any iso tracks recorded ??
To be more definitive:
A mix track or a split mix.
Cable good for static studio shoots but an radio hop is
easiest for moving camera situations, but then you need
to offer a recorded backup just in case or radio failure.
Additionally then time-coded files and a TC box on the camera
may be requested. Always check what is needed!
mike
Excellent.  Thank you for your replies.  I do more run and gun stuff but when I do more static shoots having a direct feed to the camera seems to be a better option since it “should” be better than a wireless signal ??!! :)
On 4/27/2018 at 4:08 PM, KGraham045 said:
Depends on what you route to the outputs....
I have the 633, regarding what is routed to the output.... if I want the mix going out what should I have it set to ??? I’m fairly new to the 633.  Thabk you
excellent links...  I have been watching all of those videos and learning more each day.  Thank you
