Sign in to follow this
alenK
Wave Agent split track with TRACK INFO Name?
Hello,
 I just used Sound Device's Wave Agent to split some Poly wav files from my SD 633.
 I was surprised there was not an option to include the TRACK INFO "Name" in the processed split files.
 In other words, my channel that was labeled "boom" was processed and split with the designation "_03", where as I will prefer to retain the "Boom" designation.
I used a generic file renaming utility to do what I wanted but had previously thought the ability was a basic capability with Wave Agent.
 is it possible with Wave Lab? Am I missing something?
Thank you.
Could this be a simple confusion of Filename and Metadata?
The split function retains the original filename with the added appendage of the channel counter (_03 in your example). If you now reopen the split file it should display the trackname just fine.
Hello,
 Than you for your response. I was hoping there was an automated way to include the track name in the names of the new files that result from the split process.
 I will assume by that I am not missing any opportunity to select an option to include the TRACK INFO name in the name of the split files.
 Thank you for your help.
1 hour ago, alenK said:
Hello,
 I think if they did that, postpro would become a lot more difficult as you might end up with a lot of files with the same name (the track name). How would you know where this belongs?
Hello,
For example; A 5 track Polywave which was named in the Sound Devices 633 recorder as Scene-001-01.wav would be split to 5 files named as such:
Scene-001-01_Lmix.wav
Scene-001-01_Rmix.wav
Scene-001-01_Jacks-Lav.wav
Scene-001-01_Jills-Lav.wav
Scene-001-01_BOOM.wav
As I think I now understand it, the only current option split a 5 track Polywave which was named in the Sound Devices 633 recorder as Scene-001-01.wav to 5 independent files produces naming such as this:
Scene-001-01_01.wav
Scene-001-01_02.wav
Scene-001-01_03.wav
Scene-001-01_04.wav
Scene-001-01_05.wav
Thank you.
That would be a bad idea, as you can't see the track assignment. (And that IS important sometimes.)
AFAIK (can't test now), the track names are preserved in the metadata.
There is nothing wrong with it. The metadata are still there and the number ( _3 for instance) I think is a technical requirement. Software like Pro Tools can recognise they are part of the same root file and group them in a multitrack channel, if needed. Nuendo does the same when splitting the files. I don't think there is a software giving you the option you are asking about, you need to do it yourself (quite quickly also) with a renaming software like NameChanger:
https://mrrsoftware.com/namechanger/
once you changed the name I am not sure if PT will be able to recognise your files as being part of the same root ones.
The _number is only for track assignment. (At least in Avid MC)
The metadata defines if files belong to a group.
(Why the track assignment is not in the metadata is a mystery to me.)
