Jaspar Posted June 16, 2018 Report Share Posted June 16, 2018 If I get a receiver in this block, what external antenna should I get? Quote Link to comment Share on other sites More sharing options...
afewmoreyears Posted June 16, 2018 Report Share Posted June 16, 2018 32 minutes ago, Jaspar said: If I get a receiver in this block, what external antenna should I get? You should get the ones that come with the unit, or Lectro sells a special Sharkfin style I believe suited for 941 to better answer your question.. I think I read that somewhere.. You could also call them and get the measurements for cutting your own... for transmitters and whips..My guess is the whips and the tranitter antenna will be short..but I have not seen one.. If they sell the units, they will sell the antennas otherwise, what's the point.. Quote Link to comment Share on other sites More sharing options...
ShubiSnax Posted June 17, 2018 Report Share Posted June 17, 2018 http://www.qsl.net/kd4sai/antencal.html Quote Link to comment Share on other sites More sharing options...
LarryF Posted June 17, 2018 Report Share Posted June 17, 2018 1 hour ago, Jaspar said: If I get a receiver in this block, what external antenna should I get? https://www.lectrosonics.com/US/Menu-item-for-category-listing-module-197/product/252-pca900.html Best Regards, Larry Fisher Quote Link to comment Share on other sites More sharing options...
ChrisH Posted July 10, 2018 Report Share Posted July 10, 2018 This is currently the only Antenna on the Market that will cover all your needs if you are running transmitters from 470-960. While its expensive its also the first Antenna on the market with Adjustable frequency filters I believe. It could be split passively to feed both 941 and A1/B1. I think a lot of us with bat wings that don't filter out the 600 band are going to start to feel more interned from T-Mobile blasting in 600... SKU: LFA-B-F2LFA with BNC connector, Selectable Filter HP: 470/520/550 MHz + LP: 617/663/698 MHz, Fixed Filter 935 ÷ 960 MHz (Europe/Usa)https://wisycom.com/products/product/lfa/ Quote Link to comment Share on other sites More sharing options...
Jaspar Posted August 8, 2018 Author Report Share Posted August 8, 2018 The Lectro PCA900, thank you Larry and all. Quote Link to comment Share on other sites More sharing options...
LarryF Posted August 8, 2018 Report Share Posted August 8, 2018 Several points about the antenna: 1. It has 3 dB of forward gain compared to a regular dipole or whip, a small amount of rejection at the rear and is broadband due to the angled reflector and fat arms. 2. The silver metal flange at the rear is for permanent mounting and can be bent at the various notches to handle any mounting surface. 3. There is a Lectro stand mounting kit but right now I'm getting a 404 error. You can see it on the data sheet though: https://www.lectrosonics.com/US/All-Accessories/product/pca900-2.html#data-sheet 4. Please note that this antenna says "VERT" rather than "UP". (See we learn, we're just slow.) Best Regards, Larry Fisher Quote Link to comment Share on other sites More sharing options...
13324 Posted August 9, 2018 Report Share Posted August 9, 2018 On 6/16/2018 at 7:50 PM, afewmoreyears said: My guess is the whips and the tranitter antenna will be short..but I have not seen one.. From Gotham Sound’s video on Block 941 – a 941 transmitter antenna versus typical antenna: Quote Link to comment Share on other sites More sharing options...
afewmoreyears Posted August 9, 2018 Report Share Posted August 9, 2018 So much for that ... LOL Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted August 9, 2018 Report Share Posted August 9, 2018 The block of the TX at top must be in a high block--my B19-20 etc antennas are longer than that (but not as long as the 900 tx). Quote Link to comment Share on other sites More sharing options...
