dougafresh Posted July 3, 2018 Report Share Posted July 3, 2018 Hey everybody! First-time poster here. I'm having some trouble getting rec-run timecode to trigger internal recording in my ZMT3 transmitters. I had believed the important ZMT3 menu setting was this one: Extended Menu > Timecode Menu > TC Jam Mode > Auto-Load Rec Run Quote AUTO-LOAD REC RUN - In Auto-Load mode the ZMT3 will go into record when it detects rolling time code, and will stop when the time code stops. If time code is lost because the IFB signal is too weak the unit will not stop but will continue in whatever state it was in until the time code signal is restored. My ZMT3 transmitters are all set to the same Zaxnet frequency, in the "RX" Zaxnet mode. They are correctly displaying TC that is being sent by an IFB200, but starting / stopping the TC doesn't start / stop the recording. The IFB200 is receiving timecode via BNC from a Canon C300 Mark II camera. I have the camera set to rec-run mode, so the TC only rolls when I hit record on the camera; otherwise the TC remains frozen. I have also put the IFB200 into "Transmit TP Mode," meaning that if the IFB200 is recording, then it sends a record command to the ZMT3's. This currently is working. I'd really appreciate any help you can give me. Thanks so much in advance! Quote Link to comment Share on other sites More sharing options...
