alenK Posted July 4, 2018 Report Share Posted July 4, 2018 Hi, I never had a reason to update the software on my 633, but next week we have a 6 input round table project that makes the Dugan Auto mix seem like a good option for the scratch mix. Has the latest 633 firmware been good to you? Thank you. Quote Link to comment Share on other sites More sharing options...
afewmoreyears Posted July 4, 2018 Report Share Posted July 4, 2018 I believe you should update the firmware.. for many needed fixes by Sound Devices... some for features you will use and some that you may not, but there is almost always always a few tweaks for the general system operation.. I almost always update .... If you do have a problem with something, they will always ask if you are on the latest firmware.. I have had no real issues... Your Dugan on that situation you described is the way to go... That is how I would approach it... It will do a better job of getting a mix with that many mics on an improv situation than you could manually.. If they want to remix, they can go back to the ISOs, but that mix I have had great results with right out of the bag.. May not be a scratch mix ..they may use it.. It works great.. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted July 4, 2018 Report Share Posted July 4, 2018 There are other improvements besides Dugan as well. Also--if you do have an issue with your 633 and call for support to SD, the first thing they will tell you will be to upgrade to the current firmware if you haven't already. Quote Link to comment Share on other sites More sharing options...
alenK Posted July 4, 2018 Author Report Share Posted July 4, 2018 Thank you. Quote Link to comment Share on other sites More sharing options...
VASI Posted July 4, 2018 Report Share Posted July 4, 2018 No issues with 4.51 since April 20, 2017. Approved media, L-mount batteries. Dan Dugan rocks. Quote Link to comment Share on other sites More sharing options...
Mungo Posted July 4, 2018 Report Share Posted July 4, 2018 Very rare issues reported from colleages even with fw 4.51: - machine freezes and can't be shut down, sometimes long push of menu button helps - machine resets to factory default These issues were reported as already present on other fw versions, so nothing to lose. Quote Link to comment Share on other sites More sharing options...
ACSound Posted July 7, 2018 Report Share Posted July 7, 2018 On 7/4/2018 at 8:48 PM, Mungo said: Very rare issues reported from colleages even with fw 4.51: - machine freezes and can't be shut down, sometimes long push of menu button helps - machine resets to factory default These issues were reported as already present on other fw versions, so nothing to lose. Yeah, this sometimes happens to my 633 since 2 or 3 firmwares back and does't seem like something that will be fixed soon... Quote Link to comment Share on other sites More sharing options...
