dudsound Posted August 6, 2018 Report Share Posted August 6, 2018 I'm looking at a PSC RF multi SR six-pack, the slightly older model with the D-sub connector on the back, to give me addition receiver capacity should I need more than the three slots that the SL6 provides. Receivers in my SL6 have the audio output set at -6 and this works well for a range of levels in. With the SRc in the PSC rack and plugged into input 7 of the 688, (line only), I needed to increase the output level of the receiver to +5, (ie the highest), to feel reasonably comfortable that the iso levels were not too low. Is this the experience other users have had with this or similar setups? Thanks Dudley Quote Link to comment Share on other sites More sharing options...
hobbiesodd Posted August 6, 2018 Report Share Posted August 6, 2018 I am using SRBs with the PSC Six Pack and my receivers are set to +5. Cheers, Evan Meszaros Quote Link to comment Share on other sites More sharing options...
dudsound Posted August 6, 2018 Author Report Share Posted August 6, 2018 Thanks Evan. +5 is the spot then. Dudley Quote Link to comment Share on other sites More sharing options...
