Dre Rivera Posted May 21, 2010 Report Share Posted May 21, 2010 Hey Fellow soundies i just wanted to post some shots of my cart in progress and maybe get some feed back. Thanks much dre Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted May 21, 2010 Report Share Posted May 21, 2010 Cart looks good! It appears that it might pretty heavy, not so much from the equipment (which is nice and trim) but the wheels, metal base, wooden case, etc. Probably rolls around nicely though. - JW Quote Link to comment Share on other sites More sharing options...
greg sextro Posted May 21, 2010 Report Share Posted May 21, 2010 Hey Dre, Nice cart. How do you transport it? How do you handle RF distro? Thanks, -Greg- Quote Link to comment Share on other sites More sharing options...
soundtrane Posted May 21, 2010 Report Share Posted May 21, 2010 Dre, How heavy is it ? -vin Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted May 21, 2010 Report Share Posted May 21, 2010 I like the simplicity, and also wondered if such lightweight gear could maybe have a lighter (looking) cart. But this one is very compact--nicely done. Philip Perkins Quote Link to comment Share on other sites More sharing options...
Dre Rivera Posted May 21, 2010 Author Report Share Posted May 21, 2010 Hey guys, Well the case it self isn't heavy. But jeff's got it right the base is some what heavy only because its metal and the wheels are not light either. The side of it is aluminum and the gear definitely helps compensate. it does roll really nice and smooth. I transport it on a small suv i load the box and the frame. it also not to wide so i fit it easily in the suv. heres a side shot. Quote Link to comment Share on other sites More sharing options...
Malcolm Davies Amps CAS Posted May 21, 2010 Report Share Posted May 21, 2010 What is the small plate with the holes in it used for and did you manufacture it or is it bought in? Malcolm Davies. A.m.p.s. Quote Link to comment Share on other sites More sharing options...
Dre Rivera Posted May 21, 2010 Author Report Share Posted May 21, 2010 Hey Malcolm thats just an arm i made for doing sound logs. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted May 23, 2010 Report Share Posted May 23, 2010 I know that those wheel assemblies are heavy-- I used to have some carts that used them. Since the gear is so light, you might consider lighter, lower capacity wheels with a bigger diameter, at least for the rears--they make the cart much more maneuverable and easier to get up stairs, curbs, roll across fields etc etc.. Philip Perkins Quote Link to comment Share on other sites More sharing options...
Dre Rivera Posted May 23, 2010 Author Report Share Posted May 23, 2010 ill look in to it thanks philip. Quote Link to comment Share on other sites More sharing options...
Nicole Hankerson Posted May 23, 2010 Report Share Posted May 23, 2010 Very nice cart. Nicole Quote Link to comment Share on other sites More sharing options...
Brian Posted May 28, 2010 Report Share Posted May 28, 2010 Nice and simple man, I love it! Quote Link to comment Share on other sites More sharing options...
RPSharman Posted May 28, 2010 Report Share Posted May 28, 2010 Love the setup. I'm thinking seriously about the CL9 for a scaled down cart for my next feature. Venue, 788, CL9, battery. Robert Quote Link to comment Share on other sites More sharing options...
Zack Posted May 28, 2010 Report Share Posted May 28, 2010 What is the small plate with the holes in it used for and did you manufacture it or is it bought in? Malcolm Davies. A.m.p.s. Cheese plate Quote Link to comment Share on other sites More sharing options...
Matt McGowin Posted May 28, 2010 Report Share Posted May 28, 2010 I love diamond plate. Quote Link to comment Share on other sites More sharing options...
Jan McL Posted May 28, 2010 Report Share Posted May 28, 2010 Have to say this cart got my mouth watering. One thing I don't like about the Gemini cart is not being able to put doors on it @ the end of the day for transport. Another thing, it doesn't break down. This looks like it really works for both of those issues. Very nice. Jan Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted May 29, 2010 Report Share Posted May 29, 2010 Have to say this cart got my mouth watering. One thing I don't like about the Gemini cart is not being able to put doors on it @ the end of the day for transport. Another thing, it doesn't break down. This looks like it really works for both of those issues. Very nice. Jan You have a lot more gear working than I do (now), but I found the Magliner cart was too big to get into a lot of locations I had to work in (so more cable used) and took too much effort to get up and down stairs etc, both due to weight and size. But it will take a lot of weight in a very stable fashion.... Philip Perkins Quote Link to comment Share on other sites More sharing options...
DjGo Posted May 29, 2010 Report Share Posted May 29, 2010 I like your cart very much! How is that CL9 working out for you? It's probably going to be my next purchase for cart-based work.. Diego Quote Link to comment Share on other sites More sharing options...
Dre Rivera Posted May 30, 2010 Author Report Share Posted May 30, 2010 Hey DjGo i really like the cl9. i find it really easy to use. already being a 788/cl8 user it was a great add-on. Quote Link to comment Share on other sites More sharing options...
Jan McL Posted June 9, 2010 Report Share Posted June 9, 2010 You have a lot more gear working than I do (now), but I found the Magliner cart was too big to get into a lot of locations I had to work in (so more cable used) and took too much effort to get up and down stairs etc, both due to weight and size. But it will take a lot of weight in a very stable fashion.... Philip Perkins I hear you about the stairs and size relative to Magliner use, which is why I'm spending a LOT of time deciding what-in-the-heck to do now. Will start a new post on the subject - don't want to hijack this thread. - Jan Quote Link to comment Share on other sites More sharing options...
