jason porter Posted September 6, 2010 Report Share Posted September 6, 2010 Hi all, This is the working prototype for my homemade bloop slate. It has 9 superbright LED's (very bright), a momentary push button that triggers the light AND sends a 400Hz tone to the mini-jack (line level-ish) that you see next to the trigger button. It works well when feeding the Mix-in on my SD302. It all runs on a 9V battery and I believe it draws about 100ma. I hope to add either an LCD display/counter to show take# or just keep it simple and add a layer of white dry erase board and handwrite take#'s. Some other possible tweaks are- trimpots to adjust brightness and frequency and a small amp to drive long audio lines if necessary. Let me know what you think and if you have any improvement ideas. Quote Link to comment Share on other sites More sharing options...
Angelo Waldron Posted September 6, 2010 Report Share Posted September 6, 2010 I really like that! K.I.S.S. Nothing else needed. IMO the LCD would just be a bother. Quote Link to comment Share on other sites More sharing options...
cmassey Posted September 6, 2010 Report Share Posted September 6, 2010 I don't think you would have to send a signal down long audio lines...either close to camera or via a cheap wireless mic to your mixer!!! At least that is what I have been doing with mine for the past few months. Quote Link to comment Share on other sites More sharing options...
imagist Posted September 6, 2010 Report Share Posted September 6, 2010 Great, Any chance the mini jack could be a TA3 and exit on the bottom panel rather than the same panel as the pushbutton? And I would glue a plastic protector around the push button though I'd be careful that the diameter and height didn't interfere too much with accessibility. Will you be selling them? thanks Mick Quote Link to comment Share on other sites More sharing options...
jason porter Posted September 6, 2010 Author Report Share Posted September 6, 2010 I wanted to put the jack on the bottom, but it just wouldn't fit (9V battery takes up almost the whole width) I might try a different project box to tweak the form factor. I never though that I might accidentally push the button...good idea. I may add a power switch instead. Normally, I would be happy to whip one up and sell it, unfortunately (or, fortunately) I am leaving for a 5 week job and I just don't think I will have the time. When I get back, I would be happy to do it. Thanks -Jason Great, Any chance the mini jack could be a TA3 and exit on the bottom panel rather than the same panel as the pushbutton? And I would glue a plastic protector around the push button though I'd be careful that the diameter and height didn't interfere too much with accessibility. Will you be selling them? thanks Mick Quote Link to comment Share on other sites More sharing options...
jason porter Posted September 6, 2010 Author Report Share Posted September 6, 2010 Great idea, Cleve. I have 3 X G2's sitting in a pelican case that need a job! Thx. I don't think you would have to send a signal down long audio lines...either close to camera or via a cheap wireless mic to your mixer!!! At least that is what I have been doing with mine for the past few months. Quote Link to comment Share on other sites More sharing options...
pvanstry Posted September 6, 2010 Report Share Posted September 6, 2010 Any chances i could get the schematics? I have a shoot coming up really close and could use one. THanks PAscal Quote Link to comment Share on other sites More sharing options...
imagist Posted September 6, 2010 Report Share Posted September 6, 2010 Is it the same problem with a side exit jack? I was thinking of the protector more to stop the push button being broken off than to stop accidental pushes? I've managed without one for 15 years so I guess 5 weeks is not too long thanks I wanted to put the jack on the bottom, but it just wouldn't fit (9V battery takes up almost the whole width) I might try a different project box to tweak the form factor. I never though that I might accidentally push the button...good idea. I may add a power switch instead. Normally, I would be happy to whip one up and sell it, unfortunately (or, fortunately) I am leaving for a 5 week job and I just don't think I will have the time. When I get back, I would be happy to do it. Thanks -Jason Quote Link to comment Share on other sites More sharing options...
jason porter Posted September 6, 2010 Author Report Share Posted September 6, 2010 Side mount might work. I was going to do that as well, but the sides of the case were thicker than the end panel and the jack I had wasn`t long enough to poke through. Maybe in the next version Quote Link to comment Share on other sites More sharing options...
studiomprd Posted September 6, 2010 Report Share Posted September 6, 2010 " Any chance the mini jack could be a TA3 and exit on the bottom panel rather than the same panel as the pushbutton? " it is DIY, and when you DIY, you can do it any way you want to. here are some ideas: Rugged construction, but light weight, compact, simple to operate, and rock solid reliability are givens, of course... Rechargeable - non rechargeable - external power single out - multiple outs audible (small speaker) - inaudible red lite - green lite - yellow lite - blue lite - white lite red digits - yellow digits - green digits 3 digits 2 digits - lite only - lite and separate digits (independent, too) hook - clip - Velcro attachment XLR - Lemo - Neutricon - RCA - 1/4" - 1/8" - TA5 - Hirose -Tuchel Slate mic - no mic line outs - mic outs fixed levels - level choices - continuously variable levels independent levels for slate + tone - single level for slate+tone momentary triggering- continuous triggering single freq - multi freq (selectable) 9v - dual 9v - AA - ext power large numbers - smaller numbers manual increment - auto increment 000-999 count - 0-9 + 00-99 separate counts non-TC TOD - TC (frame rates??) sunshade - flat front bottom connector - side connector rear connector top controls - side controls -rear controls - remote controls and of course: KISS Quote Link to comment Share on other sites More sharing options...
jason porter Posted September 6, 2010 Author Report Share Posted September 6, 2010 exactly what prompted me to "roll my own" Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted September 7, 2010 Report Share Posted September 7, 2010 BRAVO! Great job! Exactly what is needed for 5D etc etc shoots and no more. Great size, daylight viewable. I could wish for numbers to mark the takes with, but it would make the device WAY more complex (and you can always put a piece of tape on your box that says what "scene" you are in). This is the right device at the right time. You will be swamped w/ soundies wanting you to make them one! You don't need to drive long lines--put it on a cheap wireless! Only 1 idea: make your mini have a locking collar (but not a deal breaker). If you were selling these I'd buy one tomorrow. phil p Quote Link to comment Share on other sites More sharing options...
imagist Posted September 7, 2010 Report Share Posted September 7, 2010 " Any chance the mini jack could be a TA3 and exit on the bottom panel rather than the same panel as the pushbutton? " it is DIY, and when you DIY, you can do it any way you want to. YDS Quote Link to comment Share on other sites More sharing options...
jason porter Posted September 8, 2010 Author Report Share Posted September 8, 2010 Thanks for the compliment! I am interested in making a bunch of these for sale. If I get enough interest from the 5d/7d crowd, I will start manufacturing ASAP. What would you pay for it? -Jason BRAVO! Great job! Exactly what is needed for 5D etc etc shoots and no more. Great size, daylight viewable. I could wish for numbers to mark the takes with, but it would make the device WAY more complex (and you can always put a piece of tape on your box that says what "scene" you are in). This is the right device at the right time. You will be swamped w/ soundies wanting you to make them one! You don't need to drive long lines--put it on a cheap wireless! Only 1 idea: make your mini have a locking collar (but not a deal breaker). If you were selling these I'd buy one tomorrow. phil p Quote Link to comment Share on other sites More sharing options...
ProSound Posted September 8, 2010 Report Share Posted September 8, 2010 Thanks for the compliment! I am interested in making a bunch of these for sale. If I get enough interest from the 5d/7d crowd, I will start manufacturing ASAP. What would you pay for it? -Jason You tell us the price Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted September 8, 2010 Report Share Posted September 8, 2010 Thanks for the compliment! I am interested in making a bunch of these for sale. If I get enough interest from the 5d/7d crowd, I will start manufacturing ASAP. What would you pay for it? -Jason $200? But don't make yourself work for min. wage. If you really want to do this then come up with a good sequence for making a bunch of these (as opposed to making one), figure out your time and parts and aggro level, and see if that seems like something that is worth your time and effort. (Remember, we're a cranky bunch, and if we buy something from you we'll be bugging you for fixes, upgrades, changes etc. etc.....!) I'd consider selling through an audio dealer you like so you could avoid the phone calls and trips to UPS etc... phil p Quote Link to comment Share on other sites More sharing options...
studiomprd Posted September 8, 2010 Report Share Posted September 8, 2010 if you are really going to become a manufacturer, you might look into something like the deal Hank Garfield has with PSC for them to distribute Garfield products; distributors earn their keep by taking care of a lot if the chores a small one person operation might not relish. Quote Link to comment Share on other sites More sharing options...
jason porter Posted September 8, 2010 Author Report Share Posted September 8, 2010 That's a great idea Senator! Thanks Quote Link to comment Share on other sites More sharing options...
nhaudio Posted September 13, 2010 Report Share Posted September 13, 2010 That's a great idea Senator! Thanks do you use a 555 for the tone generator? Quote Link to comment Share on other sites More sharing options...
jason porter Posted September 14, 2010 Author Report Share Posted September 14, 2010 Yes. Quote Link to comment Share on other sites More sharing options...
fatfatjames Posted September 14, 2010 Report Share Posted September 14, 2010 i am interested!!! Quote Link to comment Share on other sites More sharing options...
jason porter Posted September 14, 2010 Author Report Share Posted September 14, 2010 If anyone is interested in getting a "bloop slate" from me, please send me a PM or email sound dot mixer at hotmail dot com and we can discuss custom options (LED color, output connector etc) and of course, price. Thanks -Jason Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted September 14, 2010 Report Share Posted September 14, 2010 Would you be willing to trade for a brand new full function remote control for the Fostex D15 & D25 studio DAT recorders? Eric Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted September 15, 2010 Report Share Posted September 15, 2010 Ok, I have an idea. Let's have a contest where everyone suggests a unique name for your "bloop slate". Then we can vote on the best entry. The winning entry gets a free slate. Could be fun and it takes the strain off of you to come up with a name. You could post the contest as a poll for a specific period of time. It's too bad your last name isn't Betty, then it could be called "The Betty Bloop Slate". OTOH you have to be old enough to get the play on words. Eric Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted September 18, 2010 Report Share Posted September 18, 2010 "Da Blooper!" Do I win? --Marc W. Quote Link to comment Share on other sites More sharing options...
