Ramsay Posted December 30, 2010 Report Share Posted December 30, 2010 Hi Group, I have to start a show at the last minute and they are requesting 30ndf 48048 24bit. I've read all the posts and will be setting up like this 744T 48048 30ndf as master clock/sync source. Boom Recorder TC 29.97, clock set to spdif from 744t, hardware sample rate 48K, file sample rate 48K. Motu Ultralight is acting as a pass through for TC to analogue track on Boom Recorder. I think this is the "proven cheat" way of setting up Boom Recorder to record 48048. Any Comments? Many thanks, Patrick Quote Link to comment Share on other sites More sharing options...
RPSharman Posted December 31, 2010 Report Share Posted December 31, 2010 This thread will answer all... http://jwsound.net/SMF/index.php?topic=1305.msg20861#msg20861 I believe you will want BR set for 29.97/48/48048, as suggested by Take in the final post on this thread. Quote Link to comment Share on other sites More sharing options...
graham Posted December 31, 2010 Report Share Posted December 31, 2010 I think that's correct. Record a file and throw it into daw of choice. I use waveagent. File should read as 29.97 & 48/48. here's another thread http://jwsound.net/SMF/index.php?topic=4776.msg35445#msg35445 Quote Link to comment Share on other sites More sharing options...
Ramsay Posted December 31, 2010 Author Report Share Posted December 31, 2010 I've done 3 test settings and put them in to Wave-agent. The Boom Recorder files all show the digitizer rate as 48K, So I think the first setting of 29.97, 48,48 will cause the least amount of confusion (I hope). They are going to open telecine tomorrow as a favor. I'm going to take the 744 and BR files in and hopefully get some definitive answers. Thanks so much for the prompt replies. I really like Boom Recorder and I hope someday it works with 48048 without any cheats. P. Quote Link to comment Share on other sites More sharing options...
graham Posted December 31, 2010 Report Share Posted December 31, 2010 The whole 48048F is a "cheat"! The settings in BR are simply what you want the DAW to read. I would like to hear the results of your telecine tests with regard to timecode accuracy in the BR reports. Keep us posted and good luck Quote Link to comment Share on other sites More sharing options...
Ramsay Posted January 3, 2011 Author Report Share Posted January 3, 2011 This was the only test that worked. All the others were off. 744T 48048 30ndf as master clock/sync source. Boom Recorder TC 29.97, clock set to spdif from 744t, hardware sample rate 48K, file sample rate 48K (not 48048). Motu Ultralight is acting as a pass through for TC to analogue track on Boom Recorder. Quote Link to comment Share on other sites More sharing options...
MT Groove Posted March 17, 2011 Report Share Posted March 17, 2011 Interesting observations. You might want to check your sound reports generated by Boom Recorder as it will show variations of timecode. Quote Link to comment Share on other sites More sharing options...
