Christian Spaeth Posted April 11, 2011 Report Share Posted April 11, 2011 You can set each recording track to record either pre or post fade. So you can either use the faders for record levels or you can use the input trim for record level. sorry for maybe not getting it - is the input trim only accessible via the display? - in other words: does it make sense to run this one standalone when I record ISOs and a mix track (for which I would change levels while recording)? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 11, 2011 Report Share Posted April 11, 2011 sorry for maybe not getting it - is the input trim only accessible via the display? - in other words: does it make sense to run this one standalone when I record ISOs and a mix track (for which I would change levels while recording)? Sorry Christian I'm not quite sure what you are asking. With nomad you can set the record channels to record post fad iso. Or you can record pre fade iso and the levels will be controlled via input trim. And the input trim is accessed from the channel set up menu. Each input has its own set up menu page. When you are on that page you can adjust the trim with the menu knob. Does that answer your question? Jack Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted April 11, 2011 Report Share Posted April 11, 2011 Sorry Christian I'm not quite sure what you are asking. With nomad you can set the record channels to record post fad iso. Or you can record pre fade iso and the levels will be controlled via input trim. And the input trim is accessed from the channel set up menu. Each input has its own set up menu page. When you are on that page you can adjust the trim with the menu knob. Does that answer your question? Jack it does! thanks! Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted April 11, 2011 Report Share Posted April 11, 2011 Jack, is the Nomad the same as the Fusion and Deva that you can record a mix track of multiple inputs ie Mix on 1 (+2), pre-fade iso on remaining tracks? Or does it only record pre or post-fade single inputs? I've sent an email to Zax directly asking this too, but you seem to be online now and in the mood for answering silly questions Thanks. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 11, 2011 Report Share Posted April 11, 2011 Jack, is the Nomad the same as the Fusion and Deva that you can record a mix track of multiple inputs ie Mix on 1 (+2), pre-fade iso on remaining tracks? Or does it only record pre or post-fade single inputs? I've sent an email to Zax directly asking this too, but you seem to be online now and in the mood for answering silly questions Thanks. Yes You can record any input to any record channel (both pre or post fade). You can record one or all input channels to any or all record channels. The short answer is the Nomad output and record matrix is infinitely variable - so I don't think you can think of an output or record option that the Nomad can't handel. Jack Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted April 11, 2011 Report Share Posted April 11, 2011 thanks for your answers Jack! one more thing - am I right in assuming that the built in transceiver will only work with Zaxcom wireless equipment? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 11, 2011 Report Share Posted April 11, 2011 thanks for your answers Jack! one more thing - am I right in assuming that the built in transceiver will only work with Zaxcom wireless equipment? If you are referring to Zaxnet - then yes. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted April 11, 2011 Report Share Posted April 11, 2011 So there is no way to press the record button only with only one hand? Quote Link to comment Share on other sites More sharing options...
Bash Posted April 11, 2011 Report Share Posted April 11, 2011 This is quite clearly a software driven 'feature' - so if you talk nicely to Zaxcom, they will most likely make a setup tick box to allow one button record. Kindest regards, Simon B So there is no way to press the record button only with only one hand? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 11, 2011 Report Share Posted April 11, 2011 So there is no way to press the record button only with only one hand? You will be able to set up Nomad to have one button transport controls. Quote Link to comment Share on other sites More sharing options...
Rick Albright Posted April 12, 2011 Report Share Posted April 12, 2011 Was the Nomad at NAB a fully functioning product capable of recording ? Realistically, when will dealers have them available for purchase ? I need one tomorrow. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted April 12, 2011 Report Share Posted April 12, 2011 " I need one tomorrow. " As with almost all new products in our current era, the early adopters will probably endure some early issues... Quote Link to comment Share on other sites More sharing options...
Derek H Posted April 12, 2011 Report Share Posted April 12, 2011 This is true, my QRX100 knows the road from Chi-town to Jersey by heart! Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted April 12, 2011 Report Share Posted April 12, 2011 We should probably go to this http://jwsound.net/SMF/index.php?topic=8499.new#new to make glenn's work easier. Too many Nomad treads. This is true, my QRX100 knows the road from Chi-town to Jersey by heart! Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted April 13, 2011 Report Share Posted April 13, 2011 As with almost all new products in our current era, the early adopters will probably endure some early issues... A saying we often used in the video bidness: "You can always tell the pioneers... those are the people with the arrows in their backs." --Marc W. Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted April 13, 2011 Report Share Posted April 13, 2011 Anyone know if you can use an external keyboard? This might be a case for one of those mini USB keyboards to edit metadata etc. There is one USB port (as opposed to a "keyboard" port on the Devas), and according to the specs it's for external data. http://zaxcom.com/Nomad.html The Specifications are up. Data Storage Internal 2 x CompactFlash External - Nomad 8 & 12 Only USB 2.0 High Speed External Media - Nomad 8 & 12 Only Flash / Hard Drive also, this was asked.... Recording Track Count 4, 6, 8 or 12 - model dependent Bit-depth Primary 24 Mirror(s) 16 / 24 Sample-rates (kHz) 44.1, 47.952, 48, 48.048 Head Room 12 to 20 dB Format Int. Slot-1: MARF II Int. Slot-2: FAT32 Ext USB. Device: FAT32 - Nomad 8 & 12 Only File Format Int. Slot-1: .ZAX Int. Slot-2: BWF-P Ext. Device: BWF-P or MP3 - Nomad 8 & 12 Only Dual Disk Recording YES Max Pre-record Duration (seconds) 10 seconds Quote Link to comment Share on other sites More sharing options...
