Zaxcom Nomad (The "Non-conjecture" thread)
Chris Durfy
  • Replies 523
  • Created
  • Last Reply
Top Posters In This Topic
Jack, Glen,
Do you have an idea why the Nomad inputs differ when sending tone from 4 channel SRa with the same gain and limiters off?
I have changed cables, receivers and still get the same result?
Must have missed it if it was mentioned.
Hey Rado,
Sorry when I made that comment on FB I thought it was about channels five and six. That you weren't getting any audio to either of those. My bad.
Yes, the -/+3db is normal.
Upgrade between Nomad 4/6 and Nomad 8/12 requires an additional board(s) to be installed and would need to return to the factory. All other upgrades are software and can be done over the phone/internet. USB recording media (3rd) is only available from Nomad 8 and up, but Mix-8 WILL BE (not enabled yet AFAIK) available on all models.
I was told by Colleen at Zaxcom that to upgrade a Nomad 4 or 6 requires modifying the hardware, and a trip back to the factory is required as you said. However, the upgrade from a Nomad 8 to a 12 is a software only upgrade and can be done remotely. She confirmed that in all cases the cost is the price difference plus a $300 service charge as John Blankenship has stated. (Even the software only upgrade from a Nomad 8 to a 12.)
Question:
there has been some hardware changes to Nomad since the first units where released (battery door fit problem, not sure what else)
When I finally receive the Nomad 8 (in about 2 months) which I ordered last October, will it be the most current version hardware-wise?
Or have there been more recent hardware changes which I may not benefit from?
Question:
As far as I know - other than a diode and a few jumpers and perhaps some resistor values there hasn't been any major hardware changes to Nomad since the first units that were shipped - and there are no plans to change any hardware.
And I'm not sure what you are referring to in regard to the battery door.
Glenn mentioned putting a piece of mylar on the inside of the battery door so if someone inserted the battery sled backwards, lithium batteries couldn't short out and start a fire.
It sounds like a good idea. Of course, another solution is to not put the battery sled in backwards.
