Boomboom Posted April 24, 2011 Report Share Posted April 24, 2011 Good news for the pan and the meters additions :-) Will the Nomad have an auto scan function via Zaxnet like the Fusion ? (auto scan then tune freqs of the Rx-Tx kits on set) Quote Link to comment Share on other sites More sharing options...
PTA Posted April 24, 2011 Report Share Posted April 24, 2011 You don't have to touch a fader to pan. In the new two bus mode your Left / Right panning is accomplished by one push of the menu knob. You will turn the menu knob to the right or left to select the channel you want to pan and then push the menu knob. You will have to touch a fader to activate the "auto-trim" for that channel though. Jack So just to clarify, one has to push the menu knob, turn to the appropriate channel, push the menu knob again to select the channel, then turn again to pan left center, or right? Quote Link to comment Share on other sites More sharing options...
glenn Posted April 24, 2011 Author Report Share Posted April 24, 2011 To pan/route a channel to a bus: Press the bus key. Then press the menu knob to select Left,Right or center. The menu knob when pressed will select through L,R,C or off. Rotating the menu knob will select any of 8 analog inputs to change the pan/route selection. The pan/bus channel selection can follow the auto-trim assignment as well. Glenn Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted April 24, 2011 Report Share Posted April 24, 2011 it would be nice to see a video... To pan/route a channel to a bus: Press the bus key. Then press the menu knob to select Left,Right or center. The menu knob when pressed will select through L,R,C or off. Rotating the menu knob will select any of 8 analog inputs to change the pan/route selection. The pan/bus channel selection can follow the auto-trim assignment as well. Glenn Quote Link to comment Share on other sites More sharing options...
glenn Posted April 24, 2011 Author Report Share Posted April 24, 2011 I forgot to post that the pan/routing function is assignable to output busses 1-2, 3-4 and 5-6 in any combination. If the pan/routing is changed it can effect any combination of bus pairs at the users discression as deturmined by a setup selection. Each bus assignment can still be individualy selected in the bus xpoint selection menu. Glenn Quote Link to comment Share on other sites More sharing options...
MT Groove Posted April 24, 2011 Report Share Posted April 24, 2011 I feel there should be an option to implement hardware trim and pan toggle switches on the optional fader pack. Quote Link to comment Share on other sites More sharing options...
PTA Posted April 24, 2011 Report Share Posted April 24, 2011 I feel there should be an option to implement hardware trim and pan toggle switches on the optional fader pack. That would be nice. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted April 24, 2011 Report Share Posted April 24, 2011 The Nagra VI comes in a choice of colors... there is even a special anniversary version! Quote Link to comment Share on other sites More sharing options...
Angelo Waldron Posted April 24, 2011 Report Share Posted April 24, 2011 If it turned into a 6-pack and a pizza at mid-night I'd buy it. Quote Link to comment Share on other sites More sharing options...
Boomboom Posted April 28, 2011 Report Share Posted April 28, 2011 Angelo; don't you think that'd make an expensive booze-pizza combo ? :-P And the damn thing's already "all dressed" ! ;-) Quote Link to comment Share on other sites More sharing options...
Boomboom Posted April 28, 2011 Report Share Posted April 28, 2011 "The Nagra VI comes in a choice of colors... there is even a special anniversary version!" ... as is the Leica M9 Quote Link to comment Share on other sites More sharing options...
bigmaho Posted May 1, 2011 Report Share Posted May 1, 2011 Hard question to answer because rf range is dependent on many variables. The ifb works on 2.4 gig while the Sennheiser G3 is UHF. Assuming the same antennas (which is unlikely), 2.4 gig works better in an enclosed space and UHF would have better range out doors. Assuming clean frequencies, the G3 should have better range. (but the G3 cannot transmit time code and transmitter control signals as well as high quality audio). Best, Billy Sarokin Glenn, I have no experience with your IFB line products. How much is the approximate range of the IFB TX out of nomad? Is it better then Sennheiser g3? Quote Link to comment Share on other sites More sharing options...
johngooch Posted June 6, 2011 Report Share Posted June 6, 2011 There is indication of compression level on each track. I am not familiar with current DEVA displays but the compression indication is exactly the same as the compression indicators on the Cameo. The compression indicator is part of the meter. Doubtful. It's not on the Fusion, or Deva, which have larger screen real-estate to play with. Though it could be done by having the track meter blink, or even having a 'virtual limiter light' turn on at the end of each meter. If it's a software thing it would be fairly easy to implement, but keep in mind that the Nomad features a new limiter in the analogue domain, so maybe not... Quote Link to comment Share on other sites More sharing options...
Erick Posted June 8, 2011 Report Share Posted June 8, 2011 is there any pictures of NOMAD display working? Gracias! Erick del Valle Santiago de Chile Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted June 8, 2011 Report Share Posted June 8, 2011 Here: http://jwsound.net/SMF/index.php?topic=8499.msg75438#msg75438 is there any pictures of NOMAD display working? Gracias! Erick del Valle Santiago de Chile Quote Link to comment Share on other sites More sharing options...
