RadoStefanov Posted May 24, 2011 Report Share Posted May 24, 2011 I own b6, cos11d, tram and ewm. I want to add a DPA to my arsenal. It seams the DPA4061 is a go to mic for theater but how does it perform in our craft? Any comments welcome. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 24, 2011 Author Report Share Posted May 24, 2011 Bump. Nobody?? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 24, 2011 Report Share Posted May 24, 2011 if you want one, you should go ahead and buy one... Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 24, 2011 Author Report Share Posted May 24, 2011 Senator.... Oleg just gave me a very good answer over skype. But anyways thanks for nothing. if you want one, go ahead and buy one... Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 24, 2011 Author Report Share Posted May 24, 2011 Just got several used with the lemo connector for sennheiser.. I tested them with sennheiser SK 5*** and they sounded so good. So full and natural. Do you guys know if the sennheiser wiring will work with Zaxcom without modification??? Is it hard to rewire them for Lectro Servo? if you want one, you should go ahead and buy one... Quote Link to comment Share on other sites More sharing options...
rich Posted May 24, 2011 Report Share Posted May 24, 2011 the wiring of the lemo is the same as the zaxcom, only thing is that the zaxcom requires pin 1 of the lemo be connected to it's shell in order to prevent rf getting into the tx and losing you range. also, the 4061 wont work with the zaxcom - the zaxcom only supplies 3v to the mic, whereas the 4061 wants 5v. the 4063 is the same as the 4061 apart from its lower voltage requirement. Quote Link to comment Share on other sites More sharing options...
LarryF Posted May 24, 2011 Report Share Posted May 24, 2011 The wiring for Lectro is pretty simple. See figure 3 on this page: http://www.lectrosonics.com/component/option,com_fss/Itemid,81/catid,4/kbartid,10/view,kb/ Best, Larry F Lectro Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 24, 2011 Author Report Share Posted May 24, 2011 Thanks. Would lectro smqv,lma and um400 supply the power for the 4061? The wiring for Lectro is pretty simple. See figure 3 on this page: http://www.lectrosonics.com/component/option,com_fss/Itemid,81/catid,4/kbartid,10/view,kb/ Best, Larry F Lectro Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 24, 2011 Author Report Share Posted May 24, 2011 Well... I can not return the mics and I like .. love how they sound better then any other lav out there. the wiring of the lemo is the same as the zaxcom, only thing is that the zaxcom requires pin 1 of the lemo be connected to it's shell in order to prevent rf getting into the tx and losing you range. also, the 4061 wont work with the zaxcom - the zaxcom only supplies 3v to the mic, whereas the 4061 wants 5v. the 4063 is the same as the 4061 apart from its lower voltage requirement. Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted May 24, 2011 Report Share Posted May 24, 2011 The DPA lavs that I have been using are 4063, low voltage model needed for Zaxcom compatibility. I love the way they sound. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 24, 2011 Author Report Share Posted May 24, 2011 Absolutely love the sound. Sounds more like a small condenser then a Lav. Or maybe the last month working with 20 b6 everyday changed my "perspective" on Lav sound. Is there any kind of modification that can be done? The DPA lavs that I have been using are 4063, low voltage model needed for Zaxcom compatibility. I love the way they sound. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 24, 2011 Report Share Posted May 24, 2011 +" Well... I can not return the mics " see, you took my advice! I suspect we all love the way they sound...you get what you pay for. ...and they are small condensers... Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 24, 2011 Author Report Share Posted May 24, 2011 The DPA website shows that they work with Zaxcom TRX900 Series DAD3057? But it says on the website: Other configurations are possible; however DPA Microphones cannot guarantee full compatibility. Now it turns out I can not use them with Zaxcom.Still not sure if they work with lectro...My biggest investment went so wrong..... Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 24, 2011 Report Share Posted May 24, 2011 " Oleg just gave me a very good answer over skype. " Ah,then it must be Skype's fault. " The wiring for Lectro is pretty simple. " you didn't get that advice over Skype, did you?? Quote Link to comment Share on other sites More sharing options...
MSpector Posted May 24, 2011 Report Share Posted May 24, 2011 +" Well... I can not return the mics " see, you took my advice! I suspect we all love the way they sound...you get what you pay for. ...and they are small condensers... They are not condensers and I hope Rado will never take your advices . MS Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 24, 2011 Author Report Share Posted May 24, 2011 I did not asked the right question.... Senator please stay on topic. " Oleg just gave me a very good answer over skype. " Ah,then it must be Skype's fault. " The wiring for Lectro is pretty simple. " you didn't get that advice over Skype, did you?? Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 24, 2011 Author Report Share Posted May 24, 2011 Larry, Would 4061 work with Lectro Digital hybrid TX like LMa, SMQV, UM400a? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 24, 2011 Report Share Posted May 24, 2011 " . See figure 3 on this page: http://www.lectrosonics.com/component/option,com_fss/Itemid,81/catid,4/kbartid,10/view,kb/ " or invest in a toll-free call... Quote Link to comment Share on other sites More sharing options...
LarryF Posted May 24, 2011 Report Share Posted May 24, 2011 The DPA has a "unique" output stage that likes a fair amount of current to achieve a low output impedance. The circuit is quite clever. The Lectro servo units (SM's, LMa's and UM400a's) can provide much more current than necessary, up to 2000uA. After all, we designed the servo input for the B6 which is another high current electret. The wiring shown for DPA, as I posted earlier, provides 500uA which is a good intermediate current value. We have a 4061 here and it is a fine mic with the Lectro transmitters. We have a number of theater users that like the DPA series and use it regularly. Best, Larry F Lectro Thanks. Would lectro smqv,lma and um400 supply the power for the 4061? Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 24, 2011 Author Report Share Posted May 24, 2011 New mexico in a different time zone. I would hate to call them 15 minutes before close time. Sorry for panicking everybody!!!! " . See figure 3 on this page: http://www.lectrosonics.com/component/option,com_fss/Itemid,81/catid,4/kbartid,10/view,kb/ " or invest in a toll-free call... Quote Link to comment Share on other sites More sharing options...
rich Posted May 24, 2011 Report Share Posted May 24, 2011 The DPA website shows that they work with Zaxcom TRX900 Series DAD3057? But it says on the website: Other configurations are possible; however DPA Microphones cannot guarantee full compatibility. Now it turns out I can not use them with Zaxcom.Still not sure if they work with lectro...My biggest investment went so wrong..... the 4063 works fine with the zaxcom when you cut off the microdot connector and solder on the lemo. the DAD3057 does not connect the shell to pin 1 - at least the one i checked anyway. pretty sure the zaxcom manual gives you a list of tested mics the 4061 was never one of them Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 24, 2011 Report Share Posted May 24, 2011 " Do you know a cheap place for rewiring " wouldn't you prefer a good place?? say, didn't LSC's service department do you a favor a while back?? Quote Link to comment Share on other sites More sharing options...
LarryF Posted May 24, 2011 Report Share Posted May 24, 2011 The calls at "five to five" are called Mouse calls because they always seem to be from a musician who owns a Lectrosonics Mouse Amp from 15 years ago, who has a gig tomorrow and has just discovered that his batteries are dead and he's misplaced his charger. Can we get a charger right out so he can have it tomorrow? We are used to it. ;-) If the phones are still on, we'll answer it and smile. Best, Larry F Lectro New mexico in a different time zone. I would hate to call them 15 minutes before close time. [snip] Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 24, 2011 Author Report Share Posted May 24, 2011 I have never forgot their favor... " Do you know a cheap place for rewiring " wouldn't you prefer a good place?? say, didn't LSC's service department do you a favor a while back?? Quote Link to comment Share on other sites More sharing options...
MSpector Posted May 24, 2011 Report Share Posted May 24, 2011 the 4063 works fine with the zaxcom when you cut off the microdot connector and solder on the lemo. the DAD3057 does not connect the shell to pin 1 - at least the one i checked anyway. pretty sure the zaxcom manual gives you a list of tested mics the 4061 was never one of them The 4061 I have for my Sennheisers 5012 works well with zfr100 , never had the opportunity to check with 900. MS Quote Link to comment Share on other sites More sharing options...
