Boomboom Posted August 9, 2011 Report Share Posted August 9, 2011 Has the search function on the site been altered in some way ? I can't seem to be able to obtain results... Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted August 9, 2011 Report Share Posted August 9, 2011 Has the search function on the site been altered in some way ? I can't seem to be able to obtain results... SEARCH is not working nicely, sorry, IPB is working on it and there should be some improvements soon. You will be able to get results but you have to do a lot of maneuvering around with the Advanced Search routines. Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted August 9, 2011 Report Share Posted August 9, 2011 Boy, Search really is screwed up... I don't know why. I just did a search for DVD-RAM and set everything in Advanced Search parameters, Show As Topics, all forums, etc., and got ZIP! I will be looking into this. Quote Link to comment Share on other sites More sharing options...
Brian Maier Posted September 20, 2011 Report Share Posted September 20, 2011 Is there a way to remove the minimum character limit on search, or a workaround? Trying to search for things like sd 552, pix 240, etc and getting told that each word has to be at least 4 characters is...frustrating. Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted September 20, 2011 Report Share Posted September 20, 2011 Evidently, even if I set search for a lower minimum number of characters, there is a limitation in MySQL databases (used by all servers, etc.) of 4 characters that overrides any of my settings on this forum. This is what I have been told by people who know a whole lot more about this than I do. The only semi-workaround is just to get creative with the search string. I have experimented a lot and you can get pretty good results, certainly with the expanded Advanced Search, by putting in multiple words. The other way to do it (which many people here are doing I believe) is do a Google Search --- in Google, enter jwsoundgroup and 552 and you may get good result within which you can then navigate to topic or subject you want. I am still investigating the possibility of integrating an independent search engine for the forum. Quote Link to comment Share on other sites More sharing options...
Laurence Posted September 20, 2011 Report Share Posted September 20, 2011 If you search for pix 240, you have two 3-letter words and the search engine won't like it. But if you search for "pix 240", you have one 7-letter word. Problem solved. Quote Link to comment Share on other sites More sharing options...
