Gene Martin Posted March 27, 2007 Report Share Posted March 27, 2007 Just wondering how any of you would go about recording the effects of a car driving. The commercial that made me curious was for the the BMW x5 driving on a race track. The sounds for the exhaust, tires ect... and how do you avoid the issue of wind noise? Open to any suggestions. Thanks! Quote Link to comment Share on other sites More sharing options...
dfisk Posted March 28, 2007 Report Share Posted March 28, 2007 Actually, you don't need to use a sound proof stage at all. When recording cars, there are two methods that I have done. First: The axle dyno. Axle dyno's connect to the drive axel of the car. This is preffered over a drum dyno, as drum dyno's make excess noise. Axel dyno's work by taking off the wheels, and connecting the machine to the drive axel. They are computer controlled. I have done this at an auto tuning place, and we put the front of the car in the garage, with the tail of the car sticking outside so we don't get slammed with fumes. If the car has a turbo charger on it, you'll want to mic that. A mic at the firewall is also nice. You will need to do some engine revs and get your head in the engine compartment to find the sweet spots. You can record with the hood up. For the tail pipe (let's just go with a single exhaust), I usually put a 57 and 421 right on the pipe...well, pointed at it about 2 to 3 inches away, but off to the side. Some suped up cars will spit fire out the pipe, and fry your mic. I'll also use a variety of different mics anywhere from 3 to 15 feet from the back of the car. Positioning will depend on how the car sounds. Note: it is important that you use a dyno for stand still recordings because dyno's put a load on the car, making it perform in such a way that it would if it were on the road. If you just hoise it up and run it without a load on it, it won't behave normally, and therefore won't sound like it should. Second: Driving This is the easiest and cheapest way to get car sounds. I usually use a lav on the air intake, a lav on the firewall, a lav taped to the back bumper right above the tail pipe, and then a 421 or 57 on a magic arm positioned just off the pipe, but pointing right at it. Make sure you have good wind protection for everything. I usually wrap the lavs in foam, and zip tie them down where I need them to go. The thing to remember is that the type of car you are recording will dictate which mics to use. Also, some cars are so loud that you can almost get away with putting the mic anywhere near it and get good sound. -Dave Quote Link to comment Share on other sites More sharing options...
Gene Martin Posted March 28, 2007 Author Report Share Posted March 28, 2007 Thanks man. I hadn't even thought of using a dyno... For my clarification, what mic/brand are you referring to as a 421? Also, what type of foam have you used and where would I buy it? Thanks again! Quote Link to comment Share on other sites More sharing options...
ProSound Posted March 28, 2007 Report Share Posted March 28, 2007 Rode MD 421 http://www.sweetwater.com/store/detail/MD421 Quote Link to comment Share on other sites More sharing options...
Travis Groves Posted March 29, 2007 Report Share Posted March 29, 2007 Whitney means Sennheiser MD 421. They can often be found used on E bay. Quote Link to comment Share on other sites More sharing options...
