studiomprd Posted October 29, 2012 Report Share Posted October 29, 2012 " Anyone else with v. 4 software Noticing that their compressor settings are not latchin? " yes Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted October 29, 2012 Report Share Posted October 29, 2012 same here, not good at all. Always at -12. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted October 29, 2012 Report Share Posted October 29, 2012 " Always at -12. " and 3:1 Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 29, 2012 Author Report Share Posted October 29, 2012 Anyone else with v. 4 software Noticing that their compressor settings are not latchin? same here, not good at all. Always at -12. See post #1021 Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 29, 2012 Author Report Share Posted October 29, 2012 Lite software allows you to choose to record any one of the 10 iso inputs or any one or the 6 output busses on each record track. Here is a view of the card routing menu for Nomad Lite: Quote Link to comment Share on other sites More sharing options...
callou Posted October 29, 2012 Report Share Posted October 29, 2012 Here is a view of the card routing menu for Nomad Lite: is this coming for the other version of nomad? ( 8 and 12) and is it a replacement for the card matrix? Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted October 29, 2012 Report Share Posted October 29, 2012 is this coming for the other version of nomad? ( 8 and 12) and is it a replacement for the card matrix? I hope not, the matrix is more flexible, and imo quicker. How would you do multiple inputs to a card track in that menu? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 29, 2012 Author Report Share Posted October 29, 2012 is this coming for the other version of nomad? ( 8 and 12) and is it a replacement for the card matrix? No that is exclusively just for Nomad Lite Quote Link to comment Share on other sites More sharing options...
Ezekiel974 Posted October 29, 2012 Report Share Posted October 29, 2012 nomad lite won't have the card mix page ? Quote Link to comment Share on other sites More sharing options...
bendybones Posted October 30, 2012 Report Share Posted October 30, 2012 In V4 the AutoChange feature is a nice start but it is still a massive waste of time to be asked to turn off mirroring before changin the primary record folder. At the very least, Nomad should turn it off automatically when I change to a new primary record folder. And if really necessary it can splash an info screen to tell me that has happened. Quote Link to comment Share on other sites More sharing options...
ncsoundmixer Posted October 30, 2012 Report Share Posted October 30, 2012 Senator - The reason I asked specifically if others were having the compressor setting not latching issue with v. 4 is that deep owl was the only reporter of this phenomenon at the time I read the post. Jack Norflus' helpful response didn't delineate whether or not Howy was aware of all user's of v. 4 having the problem or just deep owl. That is why I asked for clarification. So Senator, are you reporting that your Nomad, running v. 4, also has the compressor setting non-latch issue? Quote Link to comment Share on other sites More sharing options...
glenn Posted October 30, 2012 Report Share Posted October 30, 2012 Howy will fix the compressor parameters not sticking as soon as our Hurricane has blown over. Glenn Quote Link to comment Share on other sites More sharing options...
Zack Posted October 30, 2012 Report Share Posted October 30, 2012 I hope this doesn't replace the card mix matrix on the N12. I just want the rest of the routing matrix to open up.... (7-10, and slate). Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 30, 2012 Author Report Share Posted October 30, 2012 I hope this doesn't replace the card mix matrix on the N12. It won't. I just want the rest of the routing matrix to open up.... (7-10, and slate). That is the plan. Quote Link to comment Share on other sites More sharing options...
Zack Posted October 30, 2012 Report Share Posted October 30, 2012 **thumbs up** Quote Link to comment Share on other sites More sharing options...
soundmachine Posted October 30, 2012 Report Share Posted October 30, 2012 Is there a sensible reason that I am missing not to have the auto trim diamonds on the card display? I like to use that screen primarily because it is the only one that displays track names. Any time I want to check my auto trim levels I have to scroll through all the pages to get back to the track name display. Would it be possible to make the *Star* button function as the headphone select? Whereas when you hold it down for a second it would scroll backwards? Quote Link to comment Share on other sites More sharing options...
Zack Posted October 30, 2012 Report Share Posted October 30, 2012 Is there a sensible reason that I am missing not to have the auto trim diamonds on the card display? I like to use that screen primarily because it is the only one that displays track names. Any time I want to check my auto trim levels I have to scroll through all the pages to get back to the track name display. Would it be possible to make the *Star* button function as the headphone select? Whereas when you hold it down for a second it would scroll backwards? I have recently raised this idea on zaxcom's forums about being able to actually name inputs like we can tracks. If you're using the ENG screen to have output/auto trim visual/pan control/vFader control, you currently only see "input 1, or input 4, etc..etc..". In the tracks screen you see your track names, but lose everything visual about outputs/auto trim visual, and then no pan control or vFader control. These two screens need to find a way to meld together, and the best way I can see is to be able to actually name the inputs. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 30, 2012 Report Share Posted October 30, 2012 Who uses Z fader assign? When I use Z fader assign the gain is being controlled by the fader. Is it possible to have the same gain control as regular A and D assing where menu button changes the gain on the TX and the fader changes internal mixer level? Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted October 30, 2012 Report Share Posted October 30, 2012 soundmachine, you bookmark the input page onto the slate or com button. see manual. Plus, since you can route multiple inputs to a track, where would the diamond be on that track? not practical. Zack, I think named inputs could be very confusing. I think it's good that only card tracks can be named, so I know right away on which page I am. Zaxcom, I would welcome a guide on using the Mix-8 with Nomad, since on the Mix-8 manual there are only instructions for use with Deva. Quote Link to comment Share on other sites More sharing options...
Andy P Posted October 30, 2012 Report Share Posted October 30, 2012 Who uses Z fader assign? When I use Z fader assign the gain is being controlled by the fader. Is it possible to have the same gain control as regular A and D assing where menu button changes the gain on the TX and the fader changes internal mixer level? Apparently not - see post #265 and onwards. If it were possible, it would be great. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 30, 2012 Author Report Share Posted October 30, 2012 Is there a sensible reason that I am missing not to have the auto trim diamonds on the card display?This is already planned. Would it be possible to make the *Star* button function as the headphone select? Whereas when you hold it down for a second it would scroll backwards? You can scroll back using the headphone knob. Just push and hold. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted October 30, 2012 Report Share Posted October 30, 2012 Is there a sensible reason that I am missing not to have the auto trim diamonds? I miss the auto trim diamonds! Mellow blue dot doesn't jump out as much. Quote Link to comment Share on other sites More sharing options...
Zack Posted October 30, 2012 Report Share Posted October 30, 2012 Zack, I think named inputs could be very confusing. I think it's good that only card tracks can be named, so I know right away on which page I am. I totally disagree, technically they have a name right now "input x" and it's already confusing (when trying to relate to tracks). The ability to name input and track will allow a user to program what ever combination they desire TO ELIMINATE CONFUSION for themselves aka: "customization". Not to mention there's already a color scheme difference between an input (blue) and card track (pink). Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted October 30, 2012 Report Share Posted October 30, 2012 Hmmmmm. On my Nomad and Fusion, input one is almost always the boom, the other imputs are always TX1, TX2, TX3 and if I have enough info, or won't be hot swapping while rolling, they will become "TX1 Sandy" "TX2 Brutus" etc. My screens flip around a little because when I am looking at disc tracks, track one is a mix track (Which I *usually* use). If I flip to an input screen, the boom is now on top and everything shuffles up a position. Input2 is going to be TX1 in my case, and not in the position it was on the other screen. The Nomad is for bag use, and we are often changing things on the fly, and have to repo TXs as situations play out, all while we are still recording. I see what Christian is saying by naming disc tracks. I suppose if you are doing ISO's, and swapped TX3 from Cecil to Brett, you would then have to rename the input AND the disc track. You can't have disc tracks automatically take the input name, because a mix track's name would become mud. That might not be as easy to sort out as I hoped. I would use the other screens more if they had the assigned names. Especially as you add more channels of wireless in a hectic run+gun bag situation, it can get hectic. Quote Link to comment Share on other sites More sharing options...
Zack Posted October 30, 2012 Report Share Posted October 30, 2012 In your example Johnpaul (and i appreciate it), if you changed a TX like that, you would most likely want to rename your track name too (when doing ISO's), so how difficult/time consuming would it be to change your input label from say ( 3-Cec, to 3-Bret ) once you got the time? Honestly this would require less work than changing a tape labeling or physical cheat sheet in the bag (2 hands). Think options people.... remember the whole file naming debate we had? Some people like to use the zax naming structure, and others want to have an SD way of naming files. Well, now Nomad users have both and all is well. Quote Link to comment Share on other sites More sharing options...
