piero Posted December 10, 2011 Report Share Posted December 10, 2011 Hi everyone, I'll start working on a project with RED ONE camera, and I'll send the time code to the camera with an ERX1TCD: any idea how can i set up the TIME CODE OUTPUT LEVEL on the erx1tcd? Thanks! Piero. Quote Link to comment Share on other sites More sharing options...
MatthewFreedAudio Posted December 10, 2011 Report Share Posted December 10, 2011 Hold the "menu" button when powering up. Disable the external volume button and adjust the TC voltage to whatever level the RED needs. I haven't hooked up my Zaxcom IFB receivers to a RED camera yet but I have to many other cameras. Same principal. Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted December 11, 2011 Report Share Posted December 11, 2011 Red needs to see over 1.25v to take the code (in my experience). As always, YRMV. (your RED may vary) If you get the lock symbol on the LCD you've got a strong enough signal. Quote Link to comment Share on other sites More sharing options...
bigmaho Posted December 11, 2011 Report Share Posted December 11, 2011 I usually feed DIT with the ERX and they feed the cameras, but the few times I fed RED's directly I set the ERX tc ooutput to 2v. Also, you can set (in the menu) which pin on the stereo mini carries tc for the times you need to feed both audio and tc with one unit. Billy Quote Link to comment Share on other sites More sharing options...
Tom Visser Posted December 11, 2011 Report Share Posted December 11, 2011 2v seems to work well over here, although RED is intrinsically a little finicky. Another tip, when I first did this I set TC output to left or tip. If the mini cable is removed or inserted in the jack, for a battery change or accidental removal, the audio side, right or ring, gets a blast of 2v digital noise from the timecode completely overloading the audio input. For this reason I'd make audio left and TC the right channel. Quote Link to comment Share on other sites More sharing options...
MatthewFreedAudio Posted December 12, 2011 Report Share Posted December 12, 2011 2v seems to work well over here, although RED is intrinsically a little finicky. Another tip, when I first did this I set TC output to left or tip. If the mini cable is removed or inserted in the jack, for a battery change or accidental removal, the audio side, right or ring, gets a blast of 2v digital noise from the timecode completely overloading the audio input. For this reason I'd make audio left and TC the right channel. +1 that's a smart move Quote Link to comment Share on other sites More sharing options...
piero Posted December 13, 2011 Author Report Share Posted December 13, 2011 Just finished the first day of filming:setting the output at 2V seems to work fine. Thanks to all! Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted December 13, 2011 Report Share Posted December 13, 2011 FWIW, I recall some older threads about using the Denecke SB2 Time Code boxes with a Red. It seems, some of the earlier ones put out over two volts and had reported problems with the Red. The newer (or a modified older one) SB2 puts out a bit over 1v (I'll check that figure) and works fine. I've done voltage measurements for both of my SB2 boxes (one newer, and one older/modified) and have the numbers back at the studio. I can check them when I get back. Quote Link to comment Share on other sites More sharing options...
