RPSharman Posted December 23, 2011 Report Share Posted December 23, 2011 So I have an actress friend who is going to make a music video in the near future. I told her I'd help out. I don't want things to get too complicated, and I have no idea what kind of camera they are going to use. I own Protools Micro, so I can have music from LEFT (out to a pair of 450w JBL EON) and TC out of RIGHT (broadcast to my Denecke slate with a 216). Is it any more complicated than that? Can it even be easier with waveform matching? Do I even bother with the TC slates? I don't really want to bring my whole cart, since it's on a show. The editor is "proper" feature editor. Also a friend. So he ought to be able to handle any workflow. I guess I am asking from people who do music videos more often than I do (never), if there is a standard way to do these things AND/OR and easy way, since this will be a freebie. Thanks, Robert Quote Link to comment Share on other sites More sharing options...
old school Posted December 24, 2011 Report Share Posted December 24, 2011 If it is a 5D/7D you can just let the on board mic pick up the playback track and your editor can use plural eyes to sync each clip. If it's an Alexa or Red just feed it the PB Track. Otherwise your line of reasoning and plan of attack is solid. A freebee on your Holiday sounds like a fun way to ruin a vacation. Oh well, that's what friends are for. CrewC Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted December 24, 2011 Report Share Posted December 24, 2011 (Cross-posted while Crew was posting -- forgive any duplication.) Pretty much what you did. Also, furnish post with a copy of the prepped playback track so they can use the same time code reference. On occasion, I've also sent the playback reference track and time code track to the audio tracks of the camera for more syncing options in post. The other thing is if there are any speed changes needed -- either for shooting on film at film speeds which will be pulled-down when going to video, or for overcranking for slo-mo effects. The latter is quite common with music videos. For those, you can prepare other versions of the track with the time code adjusted accordingly. Note that some intermediate versions of Denecke slates don't handle the higher frame rates well, say maybe above 30fps or so. The original TS1 handled pretty much everything, rate-wise, and the latest version of the TS3 can handle higher speeds also. The earlier TS3 versions are more limited in that regard. I'm not so sure about the TS2 versions. If you need to nail the compatibility down further, note the version of whichever Denecke slate that you're using and call Charlie Parra. As has been noted often, Charlie, and all of the Denecke team, are quite helpful. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted December 24, 2011 Report Share Posted December 24, 2011 All fine I say. It's helpful to get a clean audio feed to the camera (lo fi is ok) so that playback can be checked immediately and post syncing in whatever style they choose is made easier. Otherwise, I hope the music is good! phil p Quote Link to comment Share on other sites More sharing options...
RPSharman Posted December 24, 2011 Author Report Share Posted December 24, 2011 Thanks for your help. @ Crew. I don't think this will happen over the holidays. I sure hope not. @ Philip. I expect the music to be awful. @ John. I have only TS3s. But I hope no off-speed will be required. Otherwise I'll be seeking more advice. Happy Holidays! Robert Quote Link to comment Share on other sites More sharing options...
MatthewFreedAudio Posted December 24, 2011 Report Share Posted December 24, 2011 Using the time code slate and an audio feed to the camera will definitely make the editor happy. PluralEyes will be of no (or very little) use on a song with any sort of repetition because the wave form on measure 4 may look exactly like the wave form on measure 104. Time code off your playback device is the best way to go and as others have mentioned, a scratch feed will help for playback on set and for the editor to double check. Quote Link to comment Share on other sites More sharing options...
Chase Yeremian Posted December 24, 2011 Report Share Posted December 24, 2011 Last one I did was pretty much what you described. I ran Pro tools off my laptop, left channel with the music, right channel timecode feeding 216. I gave the camera an audio feed direct from pro tools, as well as a mic on a stand on set that also recorded to the camera. I just made markers through the song both for intro chorus 1 verse 1 etc etc.. as well as markers that followed their shot list. And having Pro Tools with me I knew any custom request was only a few clicks away. Also if there are any time changes during the song (intro 120bpm and chorus 140bpm) You should find that out. I made my metronome lead ins ahead of time to the BPM of the song as seperate regions I could instantly move around to the marker point for the section of the song we were about to shoot. Quote Link to comment Share on other sites More sharing options...
ccsnd Posted January 4, 2012 Report Share Posted January 4, 2012 Here is my workflow for Music Videos. I run PT with a 003 I record a time code signal the exact length of the track from my sb3 outputs 1&2 drive speakers output 3 is a mono out of the track output 4 is that recorded time code reference Send camera 3&4 Time code on the camera sent from my output 4 is used as a timecode reference in avid (or FCP) video tracks line up perfectly to the audio track when imported. Post is happy Quote Link to comment Share on other sites More sharing options...
Thomas Popp Posted January 5, 2012 Report Share Posted January 5, 2012 I second this - I start by striping the file using a 744T or My fusion in the following order: Tracks 1-2 are Stereo Track 3 Mono Mix Track 4 - Analog Time Code feed From here I put it into Pro Tools and use identify beat to aline along the timeline properly to create a click track if they need it (I have been asked hundreds of times for a click track - and since I have been burned before not preparing it, I always just prepare it to be ready). Then I set up all my memory locations accordingly and label them. In terms of outputs, depending on what the song is like, I will either bust out 2 jackie srm450s, or just one. I also rarely put the speakers on stands anymore. I know people will probably disagree with me - but I have literally had 2 PA's on different jobs bump into the speakers making them fall! I use the output of the mono track to go to either the camera a video playback if they have it. I use the time code output to a Sennheiser G2 so I can have a wireless timecode hop to the slate. I have had very back luck with comteks for timecode feeds being finicky. Oh also, I always use audio suite plugins to create 3 different speeds - 50% slower, 75% slower, and 2X speed - these I tell them are only for reference, and there is no timecode. The plugins speeding up and slowing down produce artifacts and stretch the timecode out so the slate can't read it. Hope this helps! ~Thomas Popp Here is my workflow for Music Videos. I run PT with a 003 I record a time code signal the exact length of the track from my sb3 outputs 1&2 drive speakers output 3 is a mono out of the track output 4 is that recorded time code reference Send camera 3&4 Time code on the camera sent from my output 4 is used as a timecode reference in avid (or FCP) video tracks line up perfectly to the audio track when imported. Post is happy Quote Link to comment Share on other sites More sharing options...
Jeremy Childers Posted January 22, 2012 Report Share Posted January 22, 2012 Hey Guys, I have a 003 with Pro tools, and have a gig coming up in 2 weeks for playback, it will be my first playback gig with time code. We will be shooting on the Red, I read a post some where on jwsound saying that time code has a hard time or won't work if I sent over senn G2/3, I can't seem to find that thread, so any thoughts or experience with that? Also forgive my ignorance but should I send time code to the reds time ode inPut or to one of the mini xlr inputs? My only time code gigs have been super easy, jam camera using 744t, so Iam a bit confused with the whole playback And pro tools with time code. Thanks Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted January 22, 2012 Report Share Posted January 22, 2012 From a post point of view, I wouldn't send music timecode to the Red. Otherwise, you'll get a lot of duplicate clips with the exact same timecode. To me, the classic way to go is just to send the playback timecode to a TC slate, plus a scratch track to the camera, and then let the editor visually eyeball the slate and use that for syncing. But that call has to be made by the editor and/or post team. Don't forget a count-off track for the artist. This helps a lot, particularly on camera moves or dance steps, plus it helps the artist figure out where to take a "breath" on camera. Quote Link to comment Share on other sites More sharing options...
Jeremy Childers Posted January 22, 2012 Report Share Posted January 22, 2012 Thanks Marc that helps, I will talk with the editor some time this week and clearify. Quote Link to comment Share on other sites More sharing options...
Stuart Piggott Posted January 30, 2012 Report Share Posted January 30, 2012 I too have a similar shoot coming up and plan to feed the slate from the music playback track and the camera a scratch track of the audio. my question is, there is a half speed version they want playing in at points as well for slo mo, purposes (i believe they plan to shoot those sequences at 37.5 fps) what is the best thing to do regarding timecode and slate- not worry about timecode for those sections and just feed scratch track to camera? Any help gratefully received- I don't tend to do a great deal of music playback shoots! Stu Quote Link to comment Share on other sites More sharing options...
old school Posted January 30, 2012 Report Share Posted January 30, 2012 Double speed version of the song will work better. CrewC Quote Link to comment Share on other sites More sharing options...
RPSharman Posted January 30, 2012 Author Report Share Posted January 30, 2012 37.5 fps is 156% of 23.98, give or take. You can easily speed it up in Protools. TC will not be relevant for those cases. We went 200%, and the actress couldn't keep up with the words. So our slo mo stuff was without singing. Robert Quote Link to comment Share on other sites More sharing options...
Stuart Piggott Posted January 30, 2012 Report Share Posted January 30, 2012 thanks guys, JWSOUND to the rescue again! Stu Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted January 31, 2012 Report Share Posted January 31, 2012 With a version of Denecke slate that can handle it (some of the earliest TS-3s couldn't), I've had success with speeding up both the music and time code. If you've done your math right, when the track is played back at normal speed, the time code is just as if you'd done it at a normal rate. As Robert noted, the biggest problem will be with the talent keeping up. You might suggest to the director that they furnish the talent with an appropriately sped up version of the song prior to the shoot so they can practice. Quote Link to comment Share on other sites More sharing options...
nickreich Posted February 25, 2012 Report Share Posted February 25, 2012 A related question, I do a lot of this sort of work, but so far haven't been asked for playback timecode to Slate. I am usually recording live vocals during the shoot, playback timecode gets recorded to a track of the 'live' recorder as a position guide, the live recorder chases 'Shoot' timecode. Cameras all shoot the slate showing 'Shoot' TC and get audio guide track and lockits. In case I ever get asked to do it the 'classic' way as Marc W describes, how much pre-roll do you usually allow for the slate to be seen then removed from shot before music starts? nick Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted February 25, 2012 Report Share Posted February 25, 2012 ... In case I ever get asked to do it the 'classic' way as Marc W describes, how much pre-roll do you usually allow for the slate to be seen then removed from shot before music starts? It depends upon how long the cadence takes. But, think it through, then estimate and be ready to adjust on set if it's not ideal. For instance, with a cadence of: AD: "Roll Playback!" You start the playback... AD: "Roll Camera" CAMERA: "Camera Speed" AD: "Mark It" The slate is clapped and then moved out of the scene as the camera settles. Meanwhile, is there enough pre-roll for the talent to be "into it" as the portion the director wants to film gets underway? Think along those terms. A more efficient cadence is for camera to announce "Mark It" when they're at speed, thus eliminating a step. Even more efficient would be for camera to eliminate "Roll Camera" as the camera simply rolls upon hearing the playback start. Be aware that, at the beginning of the song where there is silence prior to the count in, you would need to announce "Playback Speed" when you're rolling. Lots of variations. It depends upon how a given production cares to approach it -- part tradition; part efficiency, and part of it has to do with the size of the production and how many people need to spring into action (lighting cues, background action, etc., etc., etc.) -- and also what the cadence is for non-playback shots in the production. Quote Link to comment Share on other sites More sharing options...
jhaudio Posted February 28, 2012 Report Share Posted February 28, 2012 Anyone ever shoot a music video with acoustical instruments? I.E: playing a Violin and Piano (no vocals)? Is the workflow pretty much the same or are there subtle differences since playing an instrument has its nuances moreso than just singing? Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted March 22, 2012 Report Share Posted March 22, 2012 No difference that I can see or hear. Performing is performing. I've seen post problems before where an editor deliberately chose to go to a guitar or piano close up, and anyone who really knows the instrument knows that the chord is visually wrong, but if it tells the story, that shot will get into the picture. Editors cheat all the time in music videos, sometimes stealing shots from wildly different parts of the song, just to make the cut work. To bring this discussion up to date: I had to prep a music file for playback the other day, and (with some helpful hints from Courtney Goodin) came up with some notes. One mistake my assistant and I almost made was, we're dealing with a non-I/O Pro Tools system (just Protools Native), which will read timecode but not generate sound timecode. We kept struggling to figure out a way to hose the timecode output back into channel 2, so we could play this back for a music video shoot, adding the timecode to an existing song. Courtney reminded me that (as far as we know) software cannot reinterpret a timecode stamp as audible timecode, since the program itself is creating this digital data from the initial start frame. Eventually, I realized that what we needed to do was do the opposite: add the music to an existing timecoded BWF file. I generated a new file on an SD744t using an outboard Denecke timecode generator, splitting the timecode to Channel 2 and to the 744's external timecode input, starting at 00:59:30:00. I recorded for five minutes, then took this file and loaded it into Pro Tools and spotted it into a session. Then, I dropped in the music file supplied by the client, lining up the first note precisely at Hour 1. I preceded this with a 4-beat intro for the artist. Finally, I bounced this to a 2-track BWF with music on channel 1 and TC on channel 2. The file now loads into the player just fine, and we can send channel 1 (music only) to the PA speakers (and a scratch track to camera), and channel 2 through a Comtek hop to the slate. I also prepared an identical file for the editor with music L on 1 and music R on 2, leaving the embedded TC as-is. This was one of the rare cases where I encountered people who didn't have the file already prepped for the shoot. Usually, I'm the guy on the other end of this, dealing with the dailies and final edit in post, so it's an interesting challenge being on the other end, having to prep it and set it up prior to the shoot. This newly-created file plays back fine with Courtney's excellent BWF-Widget Pro utility, and I'm confident will work for our purposes on the music video shoot. The fast-cueing capabilities of BWF-Widget make it perfect for this kind of thing. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted March 22, 2012 Report Share Posted March 22, 2012 Anyone ever shoot a music video with acoustical instruments?Is the workflow pretty much the same Yes, and Yes! Quote Link to comment Share on other sites More sharing options...
Angelo Waldron Posted March 22, 2012 Report Share Posted March 22, 2012 What's all this OCD about TC?? Yeah, shooting film use TC. For cheapshit shot on video, use the Old School method and let the camera mic pick up PB track. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted March 22, 2012 Report Share Posted March 22, 2012 Just finished an M-V with Lil Wayne for the Madonna World Tour. 2 Arri Alexas with no audio feed. TC slate fed the tc from track 2 of a 744t, audio on track 1. Audio fed to a SD 442 to 2 JBL Eons & to video assist. File supplied by production company with tc & 4 pop at the top. Had a lead sheet with all the words and matching TC numbers for internal recuing. Worked just fine. Eric Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted March 24, 2012 Report Share Posted March 24, 2012 It's nice when they just hand you a prepared file! The problem is when they don't. I agree, having a lyric sheet and timecodes is mandatory. At least if you know where the choruses are, that helps. Quote Link to comment Share on other sites More sharing options...
