All Activity
- Today
Just checked it out and unfortunately it’s a back pack harness PUBP like this one. https://www.bhphotovideo.com/c/product/264604-REG/Petrol_PUBP_PUBP_Adjustable_Harness.html
I'm about to go out today and give this Ktek Stingray a go! Thank you! If this Ktek doesn't work out I'll holler!
I'm going to work on a feature film and the caméra crew will use a Red Gemini. Did some of you work with this cam ? Is it noisy ? Because a few years ago I worked wih a RED camera (don't remenber wich one) and it was a nightmare, between takes it was a constant hair dryer noise, and during takes the fan could increase the speed and the noise...
Martin67 joined the community
- Yesterday
Christian Bourne changed their profile photo
Or use your phone to hear your correspondant using the USB input of the M2D2 and a headphone and speak into your mic sending the signal through the USB to your phone as the sound card. (I think it could work)
perimeter started following Battery storage/caddy options for rechargeable AAs
Derek H started following Free Time Stamped Sound Report App
Any chance of adding track names to the slate app? btw very cool. Anyway to make it work offline?
or just put your phone in airplane mode while recording. That's what I do.
I would see a journalist using an ipad and a phone. That way, you could edit and record from m2d2 comfortably with a bigger screen, with a phone free for any calls.....
humbuk started following Favorite Harness?
K-tec can be adjusted in many directions. I found a video of the Orca and it doesn't look bad either, I guess I'll have to compare with my K-tec. Maybe they have a better solution for deploying carbines - it should be faster. Also, nothing will stick up from the spine reinforcement (sometimes I have to put the jacket over the harness in a hurry, which is not very possible with the K-tek). The Orca also has a different middle part of the carabiner, it is not placed on the top of the bag, but on the bottom, I can't judge which is more convenient - it will have to be tried. Has anyone tested these two harnesses?
- Last week
let’s wait and see. I am skeptical about specs and actual numbers. 745 has better battery life than my 743 but still nowhere near what it is needed in my workflow. . As I mentioned I power with Sony Ltype Lithium. When I used mzd8000 with 8040 and 8060 I never cared about the battery power. Usually with medium battery.
The slate app looks hopeful. I understand it is in beta. I see i can sync the slate clock to my phone clock. Are you investigating the hook for polling the Tentacle time bar app? Also, is your slate clock really 24fps or 23.98? 23.98 is far more useful in the states. Thanks for your efforts.
https://www.instagram.com/brycegonzales/?hl=en
My numbers come directly from Schoeps and Zaxcom, because that is the equipment you say you want to use. Why are you so hung up on the MZD8000? If you want to use that ... buy a used one and do it that way. But don't equate it to the CMD42, which has published specs. Yes, SuperCMIT uses more power. 170mA according to Schoeps. It has a second capsule and a whole bunch more DSP, so no surprise there. And the MZD8000 is rated at 160mA, so on paper the CMD42 will be better than both. But all three are power hogs compared to analogue. Yes, I'm using AAs with the 745. So what? Battery life will be drop commensurately no matter how it is powered.
Display Name started following Favorite Harness?
Dan, even I might actually have an unused Petrol harness, still in plastic bag in my storage. I’ll take a peek tomorrow and send you a PM if you like.
Your numbers are off judging by the mzd8000 experience. it’s true I removed the 6 micpre converters from nomad but I did not loose any noticeable power. let’s wait and see. third of the power from using aes42 seams a crazy. Judging by mzd8000 again by the way I believe supercmit uses more power. Are you using trx745 with AA???
So after feedback I ended up forking them so one is more a field sound recording notes app and then a more advanced slate type reporting app here: https://soundrolling.com/blogs/sound-tools/simple-timecode-slate Then you can add more metadata and takes either device time or from 00:00:00:00 rolling. With the one first posted you can now add location data if you want to so you can easily document where you have taken the sounds in the export
MichalB joined the community
Hello, I also own the Nagra IS version of Danish Radio. In my unit, in the place of selecting the tape speed, there is a cap, instead of a switch. Does this mean that, as in the previous thread with ALC, there is no way to switch the speed, or is it just a safety feature and plugging in the right knob could help? Thank you for your help Michal
km6064 joined the community
Alright so I went with the Ktek standard sized stingray harness. So far it seems great! My old Petrol bag isn't the most ideal bag to use with it, because it doesn't have hooks on the upper corners against the body, but it does have two sets of hooks so I think it will work. I am thinking I should install some hooks on those corners. Maybe just some steel loops or something bolted there. I've got a job starting Thursday where I'll be running and gunning so that'll be the true test. Most of the weight lands where my lower back connects to the waist. I don't really feel it on my shoulders too much. I really appreciate the design of the carabiners, the fact that they have the little nib on the big curved part instead of the straight part. It's actually much easier than the Petrol harness. Also I quite like the six points of attachment. It is a bit of a process to connect, but there is that "shortcut" of leaving one side fully attached. The standard size fits great, but yes most of the straps are pulled out a bunch. I did raise the spine part to the topmost position. I will say that the chopped up kids shin pads really did the trick on that old Versaflex! I wore that and walked around for a couple hours without rest yesterday with that set up, and my shoulders and back feel totally fine. I did not have to do any overhead booming, which is good because then those pads would have pushed into my shoulders. Right now the bag is sitting at 26 pounds, but with all the stuff in it it is more like 35 pounds. I just don't do enough of these small bag jobs to justify purchasing a whole smaller rig. I do have a Nomad but it is installed in the big cart as a back up deck. I suppose I could pull it out; I do have a smaller bag for it. But I would (always, every time and forevermore) much rather use the Deva so I'm gonna "big bag" it as long as my body holds out! That beefy Portabrace would have likely been the next best candidate. I like the look of the Portabrace way more than the too-colorful Orca. (Sadly the timing was bad to get Jim's Petrol.) Thank you everyone for your replies!
Maybe "digital" doesn't, but the CMD42 does. The CMD42 manual specifically warns about it, and the published specs reflect that. As does my experience with the SuperCMIT ... it cuts battery life on the TRX745 by a bit more than a third. As for whether it's worth it ... that's subjective ... I don't think it is. And I think it does matter in the recorder. Zaxcom specs the Nova at 1A @ 12V with 8 channels of Rx, which is 12W. The MRX414 modules each consume 300mA @ 13V, or 3.9W each. That means the recorder itself consumes 12 - (2 x 3.9) = 4.2W on its own. That means a CMD42 will increase the power consumption of the Nova by almost 30%, whereas a CMC6 will increase it by less than 5%. I agree, let's wait for real world performance tests, but, on paper, the CMD42 will noticeably decrease battery life however it is powered.
humbuk started following OR-444 ORCA 3S (SPINAL SUPPORT SYSTEM) SOUND HARNESS
The AD analog pad and digital filters are designed for the the schoeps capsules by schoeps. Huge advantage. The conversion is 100% perfect. The filters are custom designed by schoeps to work with schoeps capsules. Actually they are custom for each capsules. Also there was an easter egg in the manual about capsules with memory. Huge potential. Don’t worry about the low cut being in a digital domain. The analog front end/AD converter freq response is 8 Hz - 96 kHz. It also captures the full dynamic range. of the capsule regardless of digital gain. In fact the ideal use will be recording both the RAW signal and the digital gain adjusted one. It seams the power is 120 mA at 10 V “AES42 phantom voltage”.
I am impatient to hear how does it sound and curious to hear if mini preamp and converter embedded in a mike body would sound better or as good as those in our high range recorders. Though I am pretty optimistic that it could be better for wireless boom with any tx that accept aes input I wonder if it would be the case for lets say a Sonosax preamp+converter. As per the mod2 features of AES42, Like low cut filters, I do not yet understand the benefits over those of the recorders since they will be applied in the digital domain, unlike a CUT1 that is applied before mike preamp and makes more sense preventing preamp or converter saturation.
Very quickly. The cmd42 will deliver the most dynamic range and sound quality compared to any other combinations. when I used mzd8000 my mkh8040s and mkh8060 sounded noticibly better going digital. I don’t know what Schoeps said about it. This will replace my cmc6. Ans if you like a wired booms the cmd42 is your best choice. Goes to 1000 feet interference trouble free on a cable. Guaranteed 964 feet.
