Everything posted by Jim Rillie
RRC charger and Audioroot battery compatability
Jim Rillie replied to Mattias Larsen's topic in Equipment
At first I found the Audioroot Neos a bit quirky even in my audio root chargers, but they have settled down and charge well in my audio root chargers. now. I think they are still hesitant in my Aaton purple chargers, even when only loading one. Will check again when back to work Monday. -
We haven’t had issues with theDSQD in 4 ch mode. I used it last year. This year my son has it, working well. I am using 2 822s in its place on my project and they work well too after the firmware update to solve crackling DPR signals.
The old ground-lift trick!
Mine is on the the messy side, but has every charger I need. The bagged ones unpacked are for v-lock batteries not used as often. Set up for transport at the moment until we start production in a week and a bit. A 1510 case plus the power supplies etc., is heavy, but the wheels help.
Having owned both I must agree. But wow, the AMI 48 was the ultimate in cool, not much headroom, though.
I wish it was always that simple!
That’s what I understand.
I did a series last year where the DP wanted to shoot at true 24FPS because of worries concerning potential LED flicker. Post wanted to work at 23.976. Julian Daboll at Technicolor is the guy I like to talk to regarding these issues. The solution decided on for sound is 24/48.048 on the recorder , then they pull down later to 23.976 and 48K. Time code on the recorder, slates, and sync boxes was 24fps It just depends on what they will do post at. If they will continue at a true 24, then we would have done 24/48 on sound.
Lots of zeros and ones.
I just started using it tomorrow
To my ears, having used both, they are the speaker equivalent of 7506s (which I used for many years, but had to go away to something that more reflected what was really there) .
The Hydra board for the PSC sixpack works for all the receivers in that sixpack - 2 six-packs with Hydra equals 12 channels of Hydra info. you can adjust all major parameters from the Cantar interface, and the display is excellent. No more fiddling around with hard to read receiver displays and fussy little buttons. Definitely a big plus for ham fisted old codgers like me. OK, that's all. I should not get into the other reasons some of us use the Cantar. Demo one, if you can, and give it a few days. Then you will be a little better prepared to make that decision. Same goes for the Scorpio - try before you buy.
Science question: Schoeps CMIT startup fart noise - what is happening?
Jim Rillie replied to Izen Ears's topic in Equipment
Only one of my CMITs exhibits this. The others are normal bump at startup. It is the second one I bought. -
Curious about the distance between antenna and antenna
Jim Rillie replied to gwak ki nam's topic in Equipment
Use to do that tape and rubber band trick with my old Microns. They had fairly long cable antennas Channel 13 VHF. -
Comtek issue, rhythmic tapping or clicking sound
Jim Rillie replied to MikeCorl's topic in Equipment
iPower 9volts have worked well for us for years when bagging it. The ticking may be caused by other things, like an LED dimmer, or cell phones too close in my experience, anything that radiates RF, but your experience leads to battery. -
Tentacle Sync MK1 Battery Replacement with Pictures
Jim Rillie replied to Elusive Sounds's topic in Do It Yourself
Thanks, Vin. That is good to know. -
I'm with Mr Gooch on this, not because I have any experience in Africa, but when working internationally as I have a few times, I would always recommend bringing your own equipment (assuming you have a kit). A Carnet makes international travelling with gear workable. Oftentimes your producer can get a Carnet for sound, and camera in the same document.
Thank, you Patrick. That is what I thought. I do currently adjust my receive 620s for that very reason, also using back pattern null for interfering signals. just like using a cardioid pattern on a mic to advantage.
Hello group, Is anyone using this antenna for comms? I am using a dipole at the moment for our crew comms signal from a DCHT to M2R receivers. Range is generally less than the incoming range of a DPR. Would like to get more usable signal range out to the crew with their M2Rs. Since the ALP 620 has a lot more gain than a dipole, will using the shark fin give us noticeably more range? Since the 620 is passive, I think the 50 mW signal will not harm the antenna. Or am i wrong? Best regards, Jim Rillie
Wow, never heard of that one in my experience.
We have found with an SNA 600 on the antenna mast connected to the transmitter with an extension cable, the range is much better.
