Everything posted by Dalton Patterson
Make sure to get one of these. They look incredible and clean. I really like mine. I'll leave the debate as to which is better, the Rycote or the Ambient XLR holder for another thread.
Ambient QRT is what I use. I came to same conclusion. These look cool, SGS QR. I like the simplified design. However, I feel like if that latch comes open for any reason then its bye bye mic. I will keep an eye out for these in person so I can get my hands on one.
no, I was just thinking/wondering that was where he got his screen name from. +1 +1, I feel this Agreed 100%
Do you know of Mack Dawg Productions? ( TrueLife, Resistance, Technical Difficulties) That's a negative ghost rider. Don't do any of that stuff. You are hurting the mixing collective. It's not your job to accept less money because some random weekend warrior wants to get in on the action and will accept less than market rates. What did he say about a COI? Thats usually my go/no go on a job. Let him cobble together different mixers from the great planes to the Atlantic. Never go down, always up.
Pick N' Pluck for the win! In conclusion, for all intents and purposes I will keep the connectors connected. Thank you both for your responses. I am unclear. Does the loss exist? However it that the loss is not practical loss ( i.e to be able to be shown on test equipment)? Are you suggesting I make a new mark every time I connect/disconnect the connector? That will add significant time to my workload over a long period of time keeping track of that process. In addition to physically taking on and off the connectors, I would also have to mark them with a line. I have heard of this process to keep track of the number of uses on components, but feel an alternative approach could be successful ( i.e. keep the antenna's connected at all times). I better have a house and be retired. Haha. I get the Idea, I am not going to worry about this issue any longer. I appreciate your time guys!@ D
Mats/Carpets/Something for damping rain sounds ?
Dalton Patterson replied to Bubu's topic in General Discussion
gutterhelmet website It’s hard to believe that the sound which this little sucker makes can make you want to tear your eyeballs out. 1. Adjust the downspout angle. Many times, the simplest fix has to do with moving the bottom of the downspout further away from the house. You can use a longer clip or a spacer to accomplish this. That way, the water doesn’t fall straight down to the bottom elbow, but instead hits the side and trickles down. 2. Swap out the bottom part of the downspout. If you take off the metal elbow where your runoff water empties out and replace it with a similar piece that’s made of vinyl or plastic, the sound of the water may be muffled instead of echoing. 3. Insulate the downspout. One of the surest ways to dampen sound is to remove surface vibrations. This can be done by wrapping foam insulators around your downspout pipe (or using spray foam to do the same thing). 4. Use a scrubber sponge. For many people, the noise comes from the sound of the water dripping or trickling onto the bottom of the downspout elbow. Attaching or gluing an old scrubber sponge to the bottom inside of the downspout may absorb the dripping water more quietly. “MAKE IT STOPPP!!!” 5. Use a shingle. The same concept works if you happen to have a piece of roofing shingle left over from an earlier roof repair or replacement. Though you may have to cut the piece to fit the downspout, it could be stuffed into the opening without gluing it to the metal. 6. Use artificial turf. Some homeowners have found peace and quiet by cutting a square of artificial turf and placing it like you would a sponge or shingle. If you have this material somewhere in your landscaping, you probably have a few scraps lying around somewhere. 7. Use a foam downspout insert. Then again, there are products that are created especially for noisy downspouts. They tend to be made of soft, malleable foam than can easily be pushed into a downspout opening and clipped to the opening’s edge. 8. Use rope. This utilizes a different concept: getting water to move down an object that is situated inside the length of the downspout. Nylon rope works well if you caulk it to the top downspout opening and run it to the bottom opening. 9. Buy a downspout chain. This actually replaces some or all of a gutter by hanging down from a gutter downspout opening and letting the water trickle down the chain smoothly and quietly. But this may not be suitable for heavy rainfall climates. 10. Put a downspout chain inside the downspout. Think of this as a combination of #8 and #9. Instead of rope, drape a downspout chain inside the downspout — or make a homemade one using a plastic chain, cable ties, and long pieces of plastic (like the straight portions of plastic clothes hangers). -
Sony F5 - F55 - FS7 RF Spray problems.
Dalton Patterson replied to workingsound's topic in Equipment
You have to schedule production for the seventh moon on the seventh month. unfortunate but true. I wish I could be of more help. The only advice I have is trouble shoot if possible, try to narrow down the RF spray source. -
Me neither, at the time I heard it. I was skeptical but retained the information. Here is some info I managed to find that explains what I was referring to as "Insertion Loss". I am not 100% this is talking about the same thing. I am referring to the loss of plating on the contact of the physical pin itself decreasing over time and therefore decreasing your RF passing through the SMA connection. I think the accurate description would be copper losses. ----------------------------------- What is Insertion Loss and how is it specified? Dec 23, 2014 Insertion Loss, expressed in dB is defined as 10*log (Po/Pi) where Po= Power Out and Pi=Power In. There are 3 main causes of Insertion Loss: Reflected losses, Dielectric losses and Copper losses. Reflected losses are those losses caused by the VSWR of the connector. Dielectric losses are those losses caused by the power dissipated in the dielectric materials (Teflon, rexolite, delrin, etc.). Copper losses are those losses caused by the power dissipated due to the conducting surfaces of the connector. It is a function of the material and plating used. In general, the insertion loss of a connector is on the order of a few hundredths to a few tenths of a dB. As with VSWR, it can be specified as a “flat line limit” or as a function of frequency. A BNC connector is specified at .2 dB maximum when tested at 3 Ghz. For the SMA, the requirement is .06*SQRRT Frequency in GHz when tested at 6 Ghz. For example, at 4 Ghz, the requirement would be .06*2 or .12 dB max. Although the connectors are specified to operate over a wide frequency range, they are only specified for testing at particular frequency because the test procedure required to obtain accurate measurements of such small losses is a very precise, and time consuming process. Amphenol RF Link ----------------------------------- For anybody curious, this all started on my end because I used to take my antennas on and off in my wireless case until somebody told me that was a bad idea because you loose .00001db of RF each time. I replied, ohh. ok. Unsure as to the validity of the statement. However after further research. I tend to follow that way of thinking and now keep my antenna's and SMA connectors connected unless necessary to disconnect. I hope this helps. Stay cool in that Vegas heat @RadoStefanov!!! Best, Dalton
Neil Young talks about analog vs. digital
Dalton Patterson replied to Jeff Wexler's topic in General Discussion
Whoa. +1 -
DPA for the win! I have had positive experiences with them as well. +1
I will help you out with this, at a reasonable rate. PM me. I understand why you want to go this route. Your requirements are very similar to a sound recordist, being that you show up and are a one man band. Kudos for even relating the two. What you need is a mini sound cart with everything strapped to it and ready to roll! I like to think about it like camping. Once you get way out there in the woods, there is no way to get your stuff if you forgot something so you have to bring everything you could possibly need with you. Mini dolly google search With something like this on the bottom. Shop around and find a good price below $100 This is a must have
Keeping current and abreast of new techniques
Dalton Patterson replied to TommygunZA's topic in General Discussion
I was very lucky to get to meet an ILM Optical Printer a few days ago. We talked for some time. He was a super nice guy and told me lots of stories that made my head spin. Here are some pics. I feel this was in my opinion the best era of film making. In the late 1980s, digital compositing began to supplant optical effects. By the mid-nineties, computer graphics had evolved to rival and surpass what was possible with optical printers, and many now consider optical printing all but obsolete.[5] Improvements in film scanners and recordersallow for a complete feature film to be processed by computers, have special effects applied, and then be processed back to film. Today, optical printing is mostly used as an artistic tool by experimental film makers, for educational purposes, or for photochemical (as opposed to digital) film restoration. As a technique, it is particularly useful for making copies of hand painted or physically manipulated film. -
Gorgeous solution. Looks very clean.
I have heard that every time you connect and disconnect a micro dot connector you are loosing contact. The more you plug and unplug, the quicker your contacts wear out. In addition to the microdot assembly being somewhat fragile. They look cool.
Mercedes Metris OR Chevrolet Express 3/4?
Dalton Patterson replied to Dalton Patterson's topic in Equipment
Thank you all for the great response. I really appreciate your time and input. Copy that. Thanks for the resource. Ah, I didn't think about that, but I agree. Kind of a double edged sword. Copy that. Copy that. Good idea. I am leaning towards the Metris for now, but I will test drive both. I am big Chevy fan, I have had good experiences and hear only good things. I am honestly looking for reasons to choose the Chevy over the Benz. I keep thinking about going to the beach, the Metris seems more inconspicuous. I think because I require a dual purpose vehicle for work/recreation the Metris will suit my purposes. I'll post when I purchase. -
Hey all, I am going to invest into a production van in the near future and I am starting my research. Any input from current owners of either platform would be greatly appreciated. I feel the Metris is more appealing visually. However, I appreciate the Chevy's ability to perform your own in-house maintenance. ( I change my own oil/brakes/anything not needing a lift). Chevy Express 3/4 Pro's- Robust Chassis Powerful V8 Self Maintenance More dealership locations ?? Con's- Heavy Not as stylish Looks like rape van Looks like commercial vehicle making it target for theft Not as customizable Sound proofing/insulation/road noise? ?? Mercendes Metris Pro's- Mercedes ( Brand perception) Sleek design Advanced cabin technology Low height for parking garages ?? Con's- Expensive maintenance Fewer service locations Unable to self service ?? Specs 2018 Chevrolet Express Cargo 2500 EXTENDED RWD 2018 Mercedes-Benz Metris Cargo 126 STANDARD ROOF Powertrain 6-Speed Automatic 8-Speed Automatic 6-Speed Automatic 8-Speed Automatic 7-Speed Automatic Drivetrain RWD RWD Fuel Economy, City -- 21 MPG Fuel Economy, Highway -- 24 MPG Fuel Tank Volume 31 gal 18.5 gal Engine Fuel Type Flex Fuel Vehicle Gasoline Power 342 hp @ 5,400 RPM 208 hp @ 5,500 RPM Torque 373 lb-ft @ 4,400 RPM 258 lb-ft @ 1,250 RPM Cylinders 8 cylinders 4 cylinders Compression Ratio 9.4:1 10.3:1 Displacement 6,000 cc 2,000 cc Bore x Stroke 4 in x 3.62 in 3.27 in x 3.62 in Safety ABS Brakes Standard Optional Driver Airbag Standard Optional Passenger Airbag Standard Optional Front Side Airbags Standard Optional Curtain Airbags Standard Optional NHTSA Crash Test Results Comfort and Convenience Air Conditioning Standard Optional Radio Standard Optional Power Windows Standard Optional Power Door Locks Standard Optional Interior Maximum Seating 5 seats 2 seats Front Legroom 41.3 in 35.8 in Back Legroom -- -- Payload and Towing Cargo Volume 284.4 cu ft 186 cu ft Maximum Payload 3,022 lbs 2,502 lbs Maximum Towing Capacity 9,800 lbs 5,000 lbs Exterior Length 244.1 in 202.4 in Width 79.2 in 88.3 in Height 84.3 in 75.2 in Wheelbase 155 in 126 in
I just got a used MM-1 on Friday. I love that little guy. I can tape it to my Zoom and get a decent plant mic recording.
More info on the USBIF, from Universal Serial Bus Website About USB Implementers Forum, Inc. USB Implementers Forum, Inc. is a non-profit corporation founded by the group of companies that developed the Universal Serial Bus specification. The USB-IF was formed to provide a support organization and forum for the advancement and adoption of Universal Serial Bus technology. The Forum facilitates the development of high-quality compatible USB peripherals (devices), and promotes the benefits of USB and the quality of products that have passed compliance testing. Some of the many activities that the USB-IF supports include: USB Compliance Workshops USB compliance test development www.usb.org Web site USB pavilions at Computex, IDF, and other events Marketing programs and collateral materials, such as retail newsletters, retail salespeople training, store end-caps, etc. USB Developer Conferences and many more... Board of Directors The USB-IF, Inc. Board of Directors is composed of the following companies and their designated representative Directors: Apple - Dave Conroy HP Inc. - Alan Berkema Intel Corporation - Brad Saunders Microsoft Corporation - Toby Nixon Renesas Electronics - Philip Leung STMicroelectronics - Joel Huloux Texas Instruments - Anwar Sadat Corporate Officers The USB-IF, Inc. Corporate Officers are: President & COO - Jeff Ravencraft Chairman - Brad Saunders, Intel Corporation Vice-President - Alan Berkema, HP Inc. CTO - Abdul R. Ismail, Intel Corporation Treasurer - Philip Leung, Renesas Secretary - Alan Berkema, HP Inc. Working Committees The USB-IF, Inc. Working Committees and their Chairpersons are: Device Working Group (DWG) - Paul Berg Compliance Committee - Abdul R. Ismail Marketing Committee - Jeff Ravencraft
USB-C is 2X as fast. 10Gbps. Thats a difference between one hour or thirty mins on a 64GB card. "The latest advance to come out of the USB Implementers Forum is the USB Type-C connector, a device with gigabits of bandwidth and can handle enough current to power a laptop. It’s the future, even if Apple’s one-port wonder isn’t." The USB C is more robust than it appears. I recently pushed a small HD off the desk and it swung from the USB C port on my MacBook Pro. I was surprised that the small USB C port did not get bent or wonked in any way. The HD never ejected, it stayed booted. I was very surprised myself that it did not eject the drive. USB2-USBC adapters, cables and accessories are not created equal. Some will work, some will not, depending on if they paid Apple. I was initially hesitant towards USB C, after using it for 7 months. I hardly think of it twice. +1, this is gospel.
