Everything posted by Dalton Patterson
Strange flaw. My WM-Connect works on 664 but not 633
Dalton Patterson replied to DanieldH's topic in Equipment
The usb port is prolly dirty. Clean ports contacts with a qtip and contact cleaner. -
audio timecode delay shift sync ultrasync one tentacle sync zoom f6
Dalton Patterson replied to Sound's topic in Workflow
Lexar is not good. -
( Sarcastic, salty comments removed) Yes, there is a way. But what you are experiencing can be more easily solved by utilizing higher end, lower sensitivity LAV mics. Rode is a good beginning and backup, but as you see, it has hard limitations. If your savy with a razor and iron you can put in a resistor and lower sensitivity, I guess you could make your own attenuation adapter cable ( casual trash talk mixed with salty comment removed). Lemme know if your curious 🧐. I’ve made lots of repairs to many different types of LAV mics. PM me for pics and how to’s.
Boom Pole Quick Release for Heavy Microphones
Dalton Patterson replied to AudioScout's topic in Equipment
Maybe have it as a dedicated pole? IDK, I jumped on the QR bandwagon but not really out of necessity. -
These have to be long gone.
Awww, poor anodizing… As a solution, next time just use a piece of bicycle inner tube tire that you cut to size and place it around the object before vice gripping them into vice grip oblivion. 🤫 Ask me how I know.
Transparent Panel protection for Smartview Duo
Dalton Patterson replied to Nathan B's topic in Equipment
For as little as $18,000! You too can boom without using your shoulders. I don’t see what the big deal is. I mean, there is a practical use for this device, just not on daily boom jobs. I see long distance booming for extended periods where this device would be used, but it creates other issues that first need to be addressed. It also has limitations that need to be ironed out by @IronFilm. (Hey Buddy!).
Apple Bluetooth earphones sound problems
Dalton Patterson replied to summerlike's topic in All Things Apple
Careful with that 2012 MacBook. Mine self destructed. Battery swelled and bent out from inside. Planned obsolescence, imho. The rest would just be my opinion, so I’ll end here. -
@monoThanks for the vid!!! Just got a LAV snake!!!
It’s deafening in person. I heard it last year some time and thought, what an engineering failure. On a brighter note. The view while driving is seamless of the ocean. I see what they were trying to do. The rails disappear at speed. It went from “atmospheric river” to now a get this… “bomb cyclone”. We used to just call it heavy rain around here in these parts.
I just got an SSL 2 USB-C. It's no 4k but it's got a 4k button! Sounds crispy for a $200 interface. I agree with Borjam this will probably not bring down the perceived value, and might bring some goodies!
Thank goodness mine doesn't, but I believe you. Smart.
Cigarette Smoke leaves a residue layer that is all kinds of bad. Unfiltered cigarette smoke was also a factor. You will need to remove this layer of residue that is causing the smell. Unfortunately the entire microphone will need to be disassembled, thoroughly cleaned, and possibly replace the capsule, it might be toast. The guts of the amp should be ok after a professional cleaning. I used to deal with this in real estate properties and vehicles. I can walk you through allot of it if interested PM me. I need to research what specific chemicals to remove this caustic residue. Your going to need to find a solvent that will eat the residue but not the finish. The capsule disassembles down to the disk/diaphragm and can be cleaning at a high risk of damage. I have had success with 99% high grade isopropyl alcohol. Use wood q-tips because they allow you to scrub a bit more than the paper ones. Tar remover? I have a pair of Technic SL1200 in flight cases from 2001 that still smell like they just came out of a nightclub in British Columbia.
I use an REL, not sure of the model. I also have a KRK Rockit 18, but it requires a DBX band pass filter to sound any good. Anything with real steep LPF will work. Remember Subs take more AC.
Cleaning a Slate with a Stuck Label
Dalton Patterson replied to RunAndGun's topic in General Discussion
Best stuff I found for removing old gaff tape residue is WD-40. I went through all the usual suspects and an experienced set dresser suggested WD-40. My only worry is that it might discolor or dissolve the actual slate acrylic. Please test accordingly. Good luck! -
I advocate for better working conditions, I know we are on the same team.
I used to love Subway. First the sneaker rubber in the bread. Then came the no tuna in the tuna. Lest we forget Jared... Subway can't catch a break, lol.
