Idaho
Sound Mixer based in Idaho. I do a bit of everything up here.
1,259 profile views
Had an experience with this and wanted to report the fix for anyone that finds themselves with the same issue. I experienced this with the module on an Alexa 35. Hop feeding Ch 1, all is good with tone and dialogue test. About an hour later I notice the meter blasting red. I go and adjust the level, only to have it repeat the issue an hour later. Every power cycle/batt swap of the camera, levels reset. This happened because the unit had sat on a resellers shelf with an older firmware version that was loaded at Sonosax. THE FIX: Update the firmware to the newest version. The DP that updated the firmware said it was a bit of a pain as process is a little wonky. So here are the steps as he describes them: Load in new firmware, restart camera, do a factory reset, restart camera, change the settings like you want them, restart the camera. This is what he said he had to do for the new firmware to "take". Your mileage may vary, but wanted to include all details. Other than that the module is great and I'm happy to have this instead of the 6-pin affair. Cheers, y'all!
Definitely have thought about doing this myself, closest I've ever gotten is putting a phone in my boom bag with my MM-1 and facing the lens out. Would love to see the results whenever you get them! (Also probably a bit too late, but a Ktek Squid might have worked as a mounting option. Hard to do fine adjustments though to get that mic in the shot)
Appreciate everyone's advice and input, especially afewmoreyears, I know veeeery little about older Comtek systems. Basically, I split my time between Idaho and LA, and when I'm down there working, it's 10-15 Comteks and Zaxcom ERXs and the lot (even some earwig fun from time to time). But up here, it's Idaho, land of the potatoes, and if you worked here (and trust me, we would have met if you did haha) you would never bother spending more than $50 on a listen in system. This is just a handy little thing I whipped up in my spare time, and hopefully everyone working in LA/Atlanta/Chicago got a good laugh (or painful groan) from the simplicity of it. And should you ever find that a P.A. bugging you about "how many wires on the day" knocks off your Comtek TX and breaks it on the floor, now you'll have one more quick fix in your arsenal to tide over the troublesome producers until said P.A. goes out and picks up a new one for you (and a diet soda of your choosing, of course.) Really though, it is great to have everyones thoughts and advice, and if I was working literally in any other state I would take Derek and afewmoreyears advice and pick up a legitimate set of older Comtek 72s right away. But, there's maybe 2 other working sound mixers within 200 miles of me, and they both use Zooms slung around their neck, so I feel pretty confident in my gear offerings for now haha. Cheers fellas, and may the flightpath gods bring you favor and good fortune.
Chris! Thanks so much for the idea, the thought hadn't even crossed my mind that they make headphone amps with more inputs than maybe 2. I'll give this a try soon, Thanks again!
SeanMAC started following NFL Boom ops and IFB on the cheap.
Hey y'all! Wanted to share something that I came up with (I'm sure I'm not the first to do this) this week. I'm a mixer in Idaho, and generally I don't really get requests for IFB/listen in etc, but every now and then it'll come up that a client would like to listen in on a scene or shot. Now, seeing how rare these requests are, and that not having it has never lost me work, I've never felt the need to drop $1-2k on a full IFB set (Comtek and the like). So instead I decided to do what you see below. Coming out of my 633, is an XLRF to 3.5mm. Then I have a Female to Female 3.5mm barrel connector. Then that connects to a 5 way headphone splitter. Going off that I have five 6-foot 3.5mm cables. Then on the end of each of those is a 3.5mm Female to Female barrel connector. The volume can be adjusted through the 633, so I set it at a volume that's comfortable and leave it there. Anyone that wants to listen in can just grab a cable and plug in their headphones (or a set of cheapies I keep with my). Sound quality is great even after going through a bunch of cheap connections. Clients can listen, the 6 foot cables can be replaced with longer ones should they get on my nerves, and all in I spent 8 dollars. Hope you guys are at least entertained by this! Thanks everyone for reading.
Hey thanks so much for all the information! I gained curiosity about it when I started seeing more and more booms on the sideline. Anyone from NFL Films have any stories to share about how NFL Mic'd up is done? I read that mics are hidden inside the centers shoulderpad? Any info on the models and technique? Super interested in anything you guys have to share. Thanks y'all!
Hey y'all! Idaho sound mixer here. I wanted to see if anyone on here has ever been, or knows anything about being the sideline boom ops during NFL games. What are your assignments, how do you deliver/send files/audio, any insight you can give would be fantastic. Being from Idaho, I would never even see a posting about the job, let alone take one. Thanks!
SeanMAC started following Multi camera question , Podcast Microphones , Experience in Russia and 4 others
SeanMAC changed their profile photo
Hey y'all! I'm a mixer from Idaho, and I've noticed there's quite a few podcasts coming out of my area, but most have limited audio quality (aka cheapo USB mics). I would love to be able to offer these various groups my services to show them how good of quality they can get with the right equipment. However, my mic collection is generally just production oriented (shotguns and lavs). What mics do you guys find work best for podcasts? I'd love to also have them work as table mics for live events etc, but I'm just interested in hearing everyone's thoughts. Any input is greatly appreciated! Thanks again!
I've got a doc shoot in Russia coming up in November, and having never been there, I come to you, fellow soundies for your expertise. What is your knowledge and experience that you can share? I'm particularly interested in the wireless spectrum over there (whether I'll be in need of buying new blocks, I've heard the upper range is best). I'm also interested in anything you can share about the country and what I should expect. We will mainly be in Western Russia. Thank you for any and all input, it is greatly appreciated.
What do you all think are the necessities of a sound bag? Regardless of mixer brand etc, I'm talking what are the things you carry in your kit that have saved you in a pinch? Cables, attenuators, converters, rubber bands, altoids (true story), whatever it is! What's in your bag of audio solutions?
Can anyone explain why the 411 is that much more expensive? Still a bit confused on this. I understand the technology but I think I might be missing critical info on manufacturing costs and such. My feeling is that it has to do with the front end filters, but I'm sure there's more to it. Why the jump in price?
For multiple wireless systems, what is your protocol? How do you space your frequencies? What anomalies have you found?
Let's talk about it! What setups do y'all use? What cameras have give you the most headaches? Timecode/scratch/mix? How do you tackle it?
I might've missed it somewhere in here, but the big multicam shows often times use 1-2 Fisher 7's. Basically a boom you can sit on (similar to a dolly) that has a telescoping arm. YouTube Fisher 7 and you can see one in action (an operator attached a GoPro to the arm so you get some neat perspectives. That is why blocking is so critical in those shows. The boom ops need to know where they can be, and where they need to be. They are some of the best in the business. It's a very elegant skill.
