Display Name
Sweden
Still photographer with interest in sound in every way.
1,759 profile views
So was DaVinci Resolve once in a time as well.
I can see Aaton or Cantar as the audio brand together with CineAlta. Sony have the financial strength and it would solidify their cinema territory quite well.
Display Name started following Waow, this is Huge ! , Aaton bankruptcy , accidentally formatted cards...recovery and 7 others
BlackMagic have a penchant for buy left overs from closed businesses and open them for the masses. And they are quite empty on the dedicated audio recorder area.
I can recommend Trancends RecoveRx which is built on open source and testdisk but with a nice gui. https://www.transcend-info.com/support/software/recoverx
When running power over USB-C PD, all involved parts communicate and negotiate voltage and amperage. That’s power adapter, cable and device. So make sure you are using a usb-c PD cable rated with enough power you need. Could this be the reason you are seeing to lower voltage?
CFx cards....and Sound Devices CF recorders?
Display Name replied to Philip Perkins's topic in Equipment
Unfortunately not. The old CF cards used ATA interface while the CFExpress uses multiple lanes of PCIe. The only thing they share are the first two letters. Everything else is totally different. But you could use a CF to SD adapter card and run the CF card with a SD card inside, instead. -
I’m not even sure that some of their products actually will return from having their production suspended. I believe the A/D converter used in the mixpre 3 is actually EOL and not produced by Asahi Kasei anymore. Those used in the 6 and 10 are still in production. So either they need to find a compatible slot in, do a pcb redesign or vacuum resellers for it. The 833 was suspended as well I believe but I don’t know which converters they are using.
For angled 3,5mm connectors I’ve used the Neutrik NTP3 when I’ve done my own soldering. They are tight to put together but the quality of them and the result are top notch.
HAWK WOOD NP1 battery used with a Varizoom Sc-302 Battery charger
Display Name replied to meesh's topic in Equipment
Here’s their compatible chart. https://www.varizoom.com/v/vspfiles/downloadables/battery-chart.pdf -
Running the mini on 3 AAA of a higher capacity model will give you 3x1.2x0.9 = 3.24Wh of energy. Going with Sony’s NP-BX1 li-ion pack would give you roughly 4.5Wh.
Also make sure you are not in USB-C file transfer mode. Or perhaps try toggle it on/off and see if the phone reacts.
Shotgun/Mics to match Track E (3.5mm jack)
Display Name replied to paulinventome's topic in Equipment
Rode have the Video Mic NTG with built in battery and can be used with both 3.5mm or usb-c as io interface. https://rode.com/microphones/videomicntg -
Denecke's TimeCode Toolbox on iOS can display and output LTC as well as accepting input of LTC signal and display it. I tested it on an old iPhone SE and setting TC Toolbox to output LTC and then jam the USOne worked great. But on the SE the app did not listen to anything else but the microphone as input. Not sure why but it should work. Will do some more tests. Edit: might be I need to get a trs-trrs for this.
Looking inside the Updater app on macOS it appears as if the 2.0.9 firmware is present. <device name="UltraSync ONE" sig="*USone" deviceType="10" updaterIncRequired="300" autoUpdate="1" rstfs="0"> <file name="USone209.a32"/> <file name="TFPUs115.tcg"/> After launching the updater, it downloads newer firmware into itself. <device name="UltraSync ONE" sig="*USone" deviceType="10" updaterIncRequired="40509" autoUpdate="1" rstfs="0" stickerText="USOne"> <file name="USone214.a32"/> <file name="TFPUs115.tcg"/> I copied the USone209.a32 from inside the app to my desktop. I then choose Open from within the updater app and loaded the extracted firmware. The Update now lists the Firmware in the lower part of the window. But I've not tried to revert my USO to that firmware.
I have not updated mine yet so I can’t tell if they behave properly. Have you tried to apply the update ones again?
