Everything posted by Vincent R.
2 sides + 1 mid/center microphone setup??
Vincent R. replied to Ascend's topic in General Discussion
I won't take that as the starting point, but rather if a stereo or other kind of omni sound will be played back mono (Phone speaker, or 1 ch BT speaker, which is, frankly, done most of the times anyways nowadays), then mono compatibility is quite of the essence. And there indeed lies the beauty of mid side. -
Surely noted. We will indeed discuss this internally because I agree that things should go as quick and possible as can be.
Hi @Blocktek, sorry to hear/read this; I will notify our US team internally. This shouldn't have happened.
Lectrosonics wiring for a Deity w.lav Micro lavalier?
Vincent R. replied to Blocktek's topic in Equipment
If any of you are planning to come to the IBC this year; Friday the 9th we are throwing a Mixer Mixer at a pub, so you are all invited. Drinks on us! We are organising this with our friends of Bubblebee Industries , URSA Straps and Hide-a-mic.
Deity Microphones will be hosting a LIVE DEMO with Eric Leek (Hide-a-mic), Simon Bysshe (URSA Straps) & Poul Mejer (Bubblebee Industries) all about 'Hiding Lav Mics' + other tips & tricks. Come and go as you please! No registration needed. IBC Deity Microphones Hide-a-mic URSA Straps Date & Time: Saturday, September 10 | 10:30 AM CEST Location: IBC 2022 | Hall 8, Booth 8.D47 | Deity Microphones
About cyclists/pedestrians and electric vehicles, my own unscientific experience as a driver of both an full electric car and electric motorcycle; the car has the sound build in. The motor cycle not. On residential roads, I always have to honk my horn a bit to warn cyclists that I am coming from behind, on the motor cycle, because it really is dead silent. Often more silent than a fellow bicycle. The car, they sense me indeed because of the speakers, so they move to the side or at least watch their backs. My car, a Hyundai Kona Electric, has quite a similar sound as the Renault Zoe
I only see the option in WaveAgent to export it to PDF or CSV; No iXML.
BWF MetaEdit has an XML export I just checked, maybe look into that if it helps/works: https://mediaarea.net/BWFMetaEdit And iXML per file basis:
Could it be a HDMI thing/delay/drift?
Not as much. Proof is in the pudding. Go check/test it out. This all started in the 90's I guess with lining up ADAT recorders and DA88s, multiple digital 8 tracks to line up sample accurate. It doesn't matter, because it is the SAME straight edge you use for both or all measurements.
The Wikipedia entry actually sums it up quite nice: "Word clock should not be confused with timecode; word clock is used entirely to keep a perfectly timed and constant bitrate to avoid timing errors that can cause data transmission errors. Timecode is metadata about the media data being transmitted. Time code can be used as an initial phase reference for jam sync using the word clock as the frequency reference." So to put it simple: word clock makes sure that 1 second is 1 second on all devices, every sample, TC makes sure you can eventually line up al devices in post. So once you import it in a DAW, it all lines up. To put it even more simple: you have 2 pieces of wood marked at exactly 1 meter because a magic ruler made sure they are at 1 meter, not 1.000001 or 0.999999. So you just butt them up against a straight edge and you are good; both lines will match. The magic ruler is word clock, The straight edge is TC.
Deity Microphones Does Timecode
Vincent R. replied to Andrew From Deity's topic in Manufacturers & Dealers
Hi Daniel; I will send you a private message so please check that. Because this does not sound correct, so I can look into this. -
No M50s, but I have a SM58 with some spit/dna from Alicia Keys, Adele and some other singers in on it, 5000$ sounds about right
of course they do degrade. What make you think microphones are an exception of the "laws of physics"? 25k of that 30k neumann is gearslutz tax by the way. *Now, because some mics are having an "epic history", might make it very much worthwhile to restore/fix, whatever. But all labour and component expenses involved, after a while, it becomes a technical total-loss (not taking the "fanatic tax" into account, sure, a "name-50/60s car model" is sometimes also worth to fix for this reason)*
On the other hand, our hearing gets worse and worse as well, over time. So I guess in the end everything evens out perfectly
Regarding microphones; maybe not a populair thing to say, but microphones degrade over time. So a decades old mic, might be "working", but is technically not the same as one that is a couple years old, or brand new. Nothing you really can do about, that is just the natural degradation of the components (condenser mic/plates not holding capacitance, thus less effective, pcb components wearing out etc etc). This all not to the point that it will fail, but indeed enough to alter the sound and the potential of the initial design. Even more so do to the nature of our work; Outside, uncontrolled, humid, not humid, cold, warm, locations.
That most likely means they do the distribution for Africa too.
audio timecode delay shift sync ultrasync one tentacle sync zoom f6
Vincent R. replied to Sound's topic in Workflow
Tentacle first gen, tentacle second gen, and 3 prototype Deity TC-1 boxes (that was the focus of my test actually, the latter 🤫) -
For what it's worth it; I recently had to do an endurance test for multiple TC devices and I used the Zoom F6 for that. Jammed the F6 once, let it run on internal TC. Had 5 TC devices connected to the Audio inputs (LTC) and recorded several polywav files and monowav files over the course of a long working day (10+ hours) without power cycling any of the devices. All files, and I mean ALL, stayed completely in time, no drift, without dropouts/skipping, etc. FW of the F6 was 1.7. -
Audio Files from Deity BP-TRX with zero Duration - Corrupt Recording
Hi Jordan, I informed our US support dept. about your support request; It seems your "ticket" was not registered for some reason. (BTW; long hold press the power button for a restart of the unit). -
We are on it. -
We are fully aware of the (huge) delay on the BP-TRX (caused by a variety of reasons) and personally I would have like to see that differently, obviously. Though, I can not give an exact date yet, we are REALLY (and this time, REALLY) close to launch. The moment I do have exact dates, worldwide, I will post it here. Apologies for the inconvenience, we learned our lessons on announcing things way ahead of time.
Recording multitrack to Android?
Vincent R. replied to Aragorn's topic in Recording Direct to Computer
for sure. My post was from the --Yeah, it is possible, capable, from a technical point of view--. Is it ideal, desirable? Neh.
