nevo
Everything posted by nevo
There is a want to buy section... you need to be a member here to see it Sent from my iPhone using Tapatalk
The 4061 is low sensitivity... I use them with smv and smqv with no noticeable hiss and they sound great. Sent from my iPhone using Tapatalk
I have a separate sd633 bag with matching RX , tho having just one cable with a controller is appealing... Sent from my iPhone using Tapatalk
Yep I've managed 25years without long throw faders And as a ISO gatherer (haha )rather than a mix engineer it' would be a nice luxury.... I have used the cl12 on jobs and while I found it nice, I didn't have any epiphany moments..... I have some coin to burn but am thinking the mixpre6 rig may be my ultimate small bag project As I work a lot of tvc jobs more often than not I'm using limited channels so I'm not sure the cl12 would get used to its full potential, Maybe next drama job I'll pick one up..... Thanks guys just this bit of dialog has cemented my thoughts that I don't need a dedicated mixer. Sent from my iPhone using Tapatalk
I'm leaning towards the cl12 as it fits in nicely with my mini cart ethos And it will also work seamlessly with my 633 bag. And yes there will be more 6 series recorders in the future it will integrate with Sent from my iPad using Tapatalk
My other thoughts are about how our job has changed with multi tracking.... We used to really have to work harder with the tools to get balance and eq right as we were mixing to 2 tracks. Now I find the more problematic parts of the job can be all the bussing of signal around set... I work a lot of TVC jobs with different video guys and equipment. And the various problems they throw at the sound dept And putting my post prod hat on ...clean isos with not a lot of eq or limiting, no wind or rustle is what I'm happy delivered to me Anyway I'm just riffing on a stream of audio consciousness... 3 days on from 4 x 80 hour weeks... my brain is awaking Sent from my iPad using Tapatalk
I'm thinking about a front end for the sd664 . I have an opportunity to purchase a used 8 channel film mixer for the same price as the cl12....original price on mixer is 3 or 4 times the control surface. In 2017, with a sd664 ,is the control surface the logical option.? In my mind it's smaller, lighter,but I guess a one trick pony . I'm throwing this out there really as a discussion. I know I'll get a lot of "it depends"but the why it depends is what interests me. The other apples with apples option is a sd688 cl12 vs a dedicated mixer recorder? The sd688 /cl12 adds the Eq and multiple bussing options that you get in a mixer and gives access to 4 xtra channels. Although I've just finished a large show with a bag/ cart rig with no mixer or surface....getting quite good at mixing the mono track on rotaries...... Weight wise the surface wins hands down, Cost wise about the same. Upgrade wise the cl12 fits in if I choose to buy a sd688 in the future. Anyway I'm sure there's a lot of people out there who have used one or the other or both, I'm interested in your thoughts in our ever changing tech environment. Cheers Nevo
I run a sk2000 /g3 iem for boom sounds pretty good Sent from my iPad using Tapatalk
Yes when I was evaluating, I noticed how noisy they were and as I needed 15 , I went with lower cost comteks, which while are lower fidelity I've never had a complaint Sent from my iPad using Tapatalk
The bst75 has sorted all my. Range issues... 300m plus.... I'm running a sk2000/G3 for boom but was getting some hits the other day.... the splitter was cheap and is worth a experiment.... Sent from my iPhone using Tapatalk
I'm needing on occasion to add a couple of my SRB to my venue antenna so a splitter might come in handy for that Sent from my iPhone using Tapatalk
Hi Robert I am trying to get better range from the M216.... whenever I have remoted the antenna it usually seems to help. I have an antenna tree with a rf venue and a modded sna for the lectro venue and comtek bst75... was just thinking i might be able to combine the comtek antenna..... alternatively I could secure the m216 up on the tree and run a longer input cable. I'll try the splitter and if it' doesn't have any benefit I'll rethink things Sent from my iPhone using Tapatalk
I've ordered a splitter and I'll do some experimenting.... thanks for everyone's help Sent from my iPad using Tapatalk
Sent from my iPad using Tapatalk Thank you Larry..... for your sage advice Sent from my iPad using Tapatalk
I was hoping if I was only using two Tx I'd be able to not use a combiner.... a mini mite would be a better solution then I guess Sent from my iPad using Tapatalk
There is method to my madness... in my quest for the smallest cart with most capacity one less antenna fits the model.....IF there is no technical reason for this not to work I'm keen to try. Sent from my iPad using Tapatalk
A question re combining TX antenna .Ive read most of the relevant threads I can find but thought I'd double check. I'm running 2 comtek transmitters off my cart. The Bst75(216) is using a modded Sna600 which is for the director etc and the m216 opt7 with the whip is for boom. I'd like to use a passive 2-1 splitter either shure or lectro to connect the m216 to the SNA I know I'd have 3db loss with the split but im unsure about any intermod OR other issues.The transmitters are a distance from each other From my research I think it should be fine with lectro ZSC24 Cheers Ant Sent from my iPad using Tapatalk
New App!!! Timecard Buddy by New Endian
nevo replied to NewEndian's topic in Manufacturers & Dealers
Is there a notes section? Sent from my iPhone using Tapatalk -
2 years with soshine..... very happy ,especially with the newer 650mah Sent from my iPhone using Tapatalk
I just want to say how great it is when a Company goes out its way to help you out at short notice and on the weekend. My phone died with my LECTRORM app and FREQFINDER... I was starting a busy drama with multi radios .... and the App Store was not playing nicely and I couldn't restore my purchases. I contacted James the developer of the apps and he went beyond the call of duty to get me new codes and get back up and running. A big thank you James Sent from my iPhone using Tapatalk
Decent mics placed well....easy Sent from my iPhone using Tapatalk
Heya I have a nagra iv you can have pm me Sent from my iPhone using Tapatalk
I use a sennheiser 2000 Tx set at hi power with a G3 iem for boom and a G3 for scratch track sounds way better then my comtek 216 system.....range wise the comtek bst75/216with sna antenna gives me best range(300 plus metres) Sent from my iPad using Tapatalk
Over the years I've seen production cut corners with sound and eventually it comes back to bite them.maybe not straight away but you only need one reshoot to blow budget and confidence. Times do change I have to fight more often than not to get a boom op on TVCs, but usually if I can justify there being enough dialog I get one , ..... As a audio post guy for many years having isos is really the way to go for many technical reasons not just level balance. A show in town used a sound sup with ZFRs .....once..... the sound guys are all back working on the next reality blockbuster I understand where your coming from but I'm not hanging up my tools quite yet. Sent from my iPad using Tapatalk
It's explained in the very first post, but basically I have a physical switch with a flashing LED, that I turn off and on between takes Sent from my iPhone using Tapatalk It known on set as the "shut the f$&k "up button Sent from my iPhone using Tapatalk
