Thanks Charlie.
I finally tracked down that bnc to mini cable - works like a charm! I appreciate the response.
Thanks to you too, Marc!
I'd be happy with "sort- of" synching as well.
My first test was at 30fps (the default), but I'm thinking 29.97 ndf would be better too, since this is for broadcast - will definitely pow wow with post people once I figure more of this out...
The DP will shoot what he calls "24fps, 48fps, and 60". We obviously won't expect the offspeed stuff to sync, but it'd be nice if we could quickly line-up the 24fps, whenever he goes to that, rather than making the editors search and search within the full songs, which is recorded on the 552 SD. I haven't figured it out yet: I can get the SB-T's to Jam, I'm pretty sure my 552 is getting the SB-T timecode, but my HPX 2700 won't slave to the external yet.
Matt,
The codec: DV 100 720/59.94p, so I'll test it next at 29.9 ndf; thanks!
There is a menu item in the camera for TC frame rates, and it only offers 24, 25, or 30; so that makes me wonder if setting the external to 30 might still make sense, since the camera doesn't offer me a menu setting for TC frame rate at 29.9...
I don't think the producer is hoping for off-speed sync, just an ability to take the full song off the sd card, and sync it when she can while lining up the offspeed stuff when she can as well. Theory seems to be that if we can get the 24fps to match up, we should therefore, know where the other offspeed stuff should roughly land as well. If she has those 24fps points as a guide, then she can also always match the sd card sound, making it easier to navigate/match sound and video in post (does that make sense?). Thanks!
_______________
I'm slaving two SB-T's off the Master clock (GR-1). Then I'm slaving the camera and mixer to those SB-T's. This will give the camera man the freedom to move around without the TC out bnc as well (since .
I've figured out how to check drift, like I said, my next problem is getting that Panasonic to slave to the SB-T.
Seems that even in F-run, all the Panasonic wants to do is work off it's internal TC generator.
I'm sure there's a menu item in the Panasonic somewhere to tell it to slave to the external TC.
I'm thinking, according to the cryptic manual, it might be in the VTR VF Indicator screen, under
TC (ind)>TCR (which, when chosen, is displayed in the V-V mode -as opposed to the E-E mode- whatever that means).
My other hope was that even if the camera is showing it's internally generated Time Code, maybe in the P2 metadata, I could find the external time code information - like maybe, just maybe, since it was on F-run, and TC input was getting info, that perhaps the camera was still recording it somewhere. ...I didn't see anything of that nature in the P2 viewer file information, though...
Finally, I think this is something that needs must be tested again next time I can get close to that camera.
...there must be a menu item that'll tell it to slave to the TC in - it's just not clear about that anywhere in the manual... that I can find.
Thanks again everyone for your input.
Please let me know if you find where in the world in the menu, I might make the panasonic slave to the sb-t timecode.
I'll keep you posted as well.
I do appreciate the feedback!
John
