Everything posted by Wandering Ear
I wish someone would put their engineering into creating active noise cancellation for the drone. An array of mics and speakers that play out of phase noise to cancel out the sound of the propellers from below. Someday ...... They're pretty vague about their tech, but it looks like a combination of beam forming and active noise processing. You have to give them some credit though, the mic is really far away from the speaker, and they are still very intelligible. I would love to hear the raw recording next to the processed.
Just took a look at the haltertech microsone video. Is the idea that the talent wears an IFB receiver that feeds a bluetooth transmitter the talent also has to wear? With a lav tx, that's 3 body packs on talent. At that point an induction earwig might work just as well with only having to wear the IFB receiver. These may sound better though. I'm still generally happy with my Phonak Invisity's, I kind of dread the day when one or two breaks and I'm forced to change systems since the invisity' aren't available or repairable.
I asked Zaxcom once about the possibility of changing the X line to Lemo. I was told internally the X uses the same board as the Flex and there wasn't enough room to put a lemo on it.
Network switch for a small Dante network, yes or no?
Wandering Ear replied to Ben B's topic in Equipment
I have powered my edgerouter x from my bds before, so you should be fine. Hey Doug. The throughput I'm referring to (if i had checked my spelling) is the switch capacity, not the line rate. While each port runs at 1Gbps, the switch internally can only handle so many packets per second, and not all switches stack up. In a common unicast setup this will probably never become an issue. In larger multicast workflows a lot more data has to be handled by the switch without bottlenecks, even though each line can only handle 1Gbps. I don't mean to say the Netgear won't work or perform well. I own a netgear GS105e also, and have used it without issues in the past. I also own 3 varieties of the ubiquit, and a cisco SGxxx (can't remember which model). I can't find a pps rate for the netgear that I own right now, and the edgerouter x is lower than the edgerouter lite, so it's possible my memory is off. When I bought these several years ago I remember having to research the throughput because I ran into issues in my studio network, and increasing the internal switching capacity fixed my speed / bandwidth issues, even though all the networks were 1Gbps throughout. I settled on the ubiquiti as a good balance between switch capacity and low cost. I also find them a lot more configurable than the netgears. For example on one of my edgerouters I run a wireguard server for remote access. +1 to running VLANs. -
I use 2 ubiquiti edgerouter x (primary/secondary) and love them. They are affordable, small, power efficient, and work great with Dante. They have higher throughout than their Netgear etc cousins, and are really flexible. One thing to consider with a switched network is ip assignments. Static ip's work if you don't change your setup, but if you're like me and constantly changing which devices your using on each job, them a dhcp server is a most. The ubiquiti can be programmed as a switch (not router) that also had a dhcp server. That's a nice bonus for a self contained system like your cart system would be, and can be easily turned off to plug into another network. I also use an edgerouter 10x when I need more ports. -
Pro Tools 2021.6 doesn't support video on M1 Mac
Wandering Ear replied to Naga's topic in The Post Place
Thanks for the heads up. -
I bought the JBL soft bag and it's great. Padded, well built. Backpack straps that hide in a pocket when not needed and a cable pocket on the front.
I bounce back and forth between production and post. The biggest challenge I find is scheduling, and as I get busier in production I end up having to turn down the post jobs to the point that I don't do very many anymore. I find post schedules to be much more fluid and require a lot more flexibility. It's all commercial and corporate in post for me, which is different than feature length projects. I do feel that mixing in post makes me a much better production mixer, and is really worth it.
I have a short XLR cable with a 3rd order filter built in made by Rycote. I think it's called the Tac!t. Not sure if they still make it, but it's worked well for me in the past.
Hey! That's great news (sort of... ). I forced my phone to forget the BT connection and it hasn't turned off in 2 days. I'm fairly confident this is the culprit. Although it's annoying, at least it's easy to avoid now that we've confirmed the cause. Support told me the product team was considering adding the ability to disable that feature, but it won't be until end of the year likely. Hopefully they come through. Thanks helping me confirm this.
New product from Schoeps
Wandering Ear replied to Matthias Richter's topic in Manufacturers & Dealers
This looks great!!! I love my DPA 4098's, and I'm sure I'll love this too. -
Do you folks use bluetooth and the phone app with this speaker? I have suspected for a while that it may be related to the bluetooth connection. One thing I discovered today after it turned off twice in the morning, was that all the lights were off except the bluetooth button, and I was able to wake it back up by connecting to it with the JBL app. Now I'm thinking that the auto power save only kicks in when it's connected to my phone. I've got a week more on this show on the stage, so hopefully I can do some more controlled testing and get to the bottom of it. If I have to ditch that app to make it work, I don't mind.
For me, this would be a set and forget device, so I might not even use a screen. I would probably just VNC in to make changes. That being said, a small touch screen could be a nice addition, or planning on just using my phone as the interface (via vnc). Either way it would be low resolution, like 640x480. Thanks!
- 46 replies
- video lag
- sound sync
That's great Bouke! Any chance of a linux compatible version? I'm thinking throw this on a raspberry pi with a single channel interface and you have a small hw delay box powered by DC power. Thanks
- 46 replies
- 1
- video lag
- sound sync
I went searching for a delay box for a series of live vr shows to get us up to 2 secs, and I never found a suitable small unit. I ended up always stacking delays, sometimes combining an fx bus and output delay on my console. I am still looking for a good solution for my regular sound cart which relies on Zaxcom recorders instead of my SQ5 console. I use a dbx with my console system, but it's rack mount and ac powered which doesn't fit well with my primary sound cart. Is the Behringer shark still made? When I search for it I come up with a lot of product listings show "No longer available".
- 46 replies
- video lag
- sound sync
This is good to hear. Maybe there is an issue with my unit, and not a software problem. All in all I love the speaker, and it's sound quality and volume are great.
Not yet, but I've been really slammed with work so I've had limited time to dig around.
Support told me the product team might add the ability to turn it off in a firmware update, but sounds like that couldn't happen until later this year. This is what I got from support originally: "I know that there is a auto standby on the Eon Compact, but what we have been unable to confirm is that the threshold for that is. I can confirm that it is 20 minutes of operation below the threshold it will fall asleep." "With regards to a possible solution, if the paging system has a way to incorporate a short tone or chime, the speaker has a 3-4 second recovery from sleep. If the chime was loud enough to wake it, then a page could be made after power restores to the microphone." - Obviously not a workable solution for me. "the only reason we knew it was a feature and not a bug is because of the internal documentation available that records it." - AKA it's not in the public manual which frustrates me! I'm not really sure the auto standby is what I'm experiencing either. The power off I experience doesn't seem to be scheduled, it seems random. If it was shutting off after 20 minutes of no sound, then it should be off every day after we come back from lunch, but that's not the case, it's usually still on and working. Sometimes it will turn off 2 or 3 times in the morning, then run all day without interruption. Some days it runs all day with out ever turning off like I want it to. Part of me wonders if it has something to do with my phone bluetooth connection to the speaker for the control app, which I only use occasionally. I wrap this show in a few more weeks, so I can hopefully do some more controlled testing later this month.
I recently purchased this JBL for on set work and it's pretty fantastic! https://jblpro.com/eon-one-compact It's been mainly a VOG with occasional playback. Clean sound, lots of volume, and designed to sit on the floor angled up in a monitor profile. I haven't tested the battery life (reported at 12 hours) as I usually just run a stinger and XLR from the directors monitors, so the battery only plays for short scenes or while moving around. One issue I've been having is that sometimes it seems to turn itself off and I can't figure out why. Support told me there is an auto power save mode (not in any documentation!) but it should turn back on with signal. However I'm using a phantom powered mic directly in (Shure MX412D), and phantom also turns off so the mic goes dead and can't produce any signal to turn it back on. Any one else using this speaker and experiencing the power downs? The JBL carry bag is great too. All in all this is the speaker I've wanted in my kit for many years.
countryman Need Advice on Headsets for a Fitness Video
Wandering Ear replied to joshneal's topic in Equipment
I did a full series of workout videos with the DPA 6066's and I was really impressed. The new style dual ear mounts were really solid, and I especially liked that I could change the boom length. This allowed me to pull the mic back behind the mouth a bit. It looked better on camera and had less issues with breaths / wind / noise during high exertion / cardio work. -
A lot of the sound of a piano is resonated from the sound board and not just directly from the strings. When close mics inside the body are picking up too much action noise (or are being seen), try placing mics underneath the piano to capture the resonance of the sound board. I've had good success in the past using DPA 4098's inside on the plate pointed up at the open lid. In addition, room mics will help a lot smooth out the close mics, even if the room doesn't have the best acoustics.
