Everything posted by karlw
Hi Matthias, the workaround is to disable the remote control function (rc=off).
For future reference: any passive antenna is reciprocal: it has the same characteristics (pattern, gain) as a receive antenna and as a transmit antenna. Most active antennas cannot be used as transmit antennas since the amplifier only works one way. There are recent active antennas, like our ALP690, that can be used either way. When powered, it is an active antenna, and when not powered, it is a passive antenna and can be used that way for transmitting.
The cost depends on the unit/s involved - usually it requires replacing the RF board in the transmitter and receiver. It is usually about 1/3 to 1/2 the cost of buying them new. Not all older models can still be re-blocked. Please reach out to our service dept. at service.repair@lectrosonics.com with specific questions, and they'll give you exact quotes by model and let you know if the models you're asking about can be re-blocked.
Hi roundbadge, It may be interesting to note that the DPR system is quite flat in the low frequencies (see below trace showing frequency and phase response), especially when the HPF is set to 25 Hz (lowest setting). That said, there is a gentle rolloff down to -3 dB at 20 Hz. Perhaps the A10 has a slight bump in the lower frequencies? Nothing wrong with that - the goal is of course for these things to "sound good" which is certainly a subjective thing.
Frank, if you haven't already, please contact the Lectrosonics Parts & Repair dept. at service.repair@lectrosonics.com so they can log those serial numbers as "stolen" and we'll keep an eye out for your gear if it ever comes in for repair.
Hi Daniel, I think this is the video you are thinking of - it was part of my "Wireless Side Chats" series early in the pandemic shutdown: https://www.youtube.com/watch?v=TSnAUjgZoTI It is an overview of RF spectrum, how wireless mics fit in, and a brief summary of some of the first practical systems that were used for broadcast, stage productions, and TV/Film. It doesn't go into a lot of detail about the time period in question, nor specifically about wireless mics for film, per se. -Karl
I've been playing with a pair of these for the past couple of days and all I can say is "wow" these are great. For the price? Crazy! Very good sound, comfortable, simple design, and look they will hold up quite well. They are a no-brainer in my book.
In addition to Larry's recommendations, I will suggest looking at some band filtering and possibly attenuation. The ALP690 antenna offers both. With your ALP620s and short cables, you are likely pulling in more RF than you really need, which raises the noise floor and can increase intermods in the receiver. By putting a bandpass filter at "6" on the antennas (470-608) and then bringing down the gain by say 3dB (set the gain to -3), you will see your noise floor go down and also you'll reduce the possibility of strong out-of-band signals desensitizing your receivers.
- 33 replies
Hi Jon, did you purchase this kit new or used? What are the firmware versions and serial numbers, please?
Since our daughter is off to college, Jane and I have inherited two rabbits and a mouse - the mouse "Baby" passed away last week at the ripe old age of about 1.75 years... the rabbits - "Bert" is a California, and "Francis" is an American Sable. Super quiet, fairly clean, gentle animals. But they can be mischievous, too. Every once in a while, they'll figure out how to get out of the cage, and just hop around and check stuff out, hide under the bed, etc. Fortunately, they are not "chewers" so nothing gets damaged.
THS - if this was early enough in the "discovery process" (figuring out the cause) then yes, it's possible that the hardware fix had not yet been developed and thus there was no warranty work to correct it. But, you bring up a good point about the wiring - different lav mic wiring schemes show a lot of variation in this problem. And, you are correct that the "servo only" wiring schemes (figs 9, 10 and 11 on this page) do not exhibit the issue. Since the "universal" wiring allows wiring of transmitters that were made pre-2005, I would suggest to everyone to use the servo-only wiring unless you have older transmitters. Servo-only wiring is generally quieter overall as well. https://www.lectrosonics.com/Support/Microphone-Wiring/uhf-transmitter-5-pin-input-jack-wiring.html
Hi Chickaboom, One thing to test is to turn off remote response (RC off) in that transmitter and see if the whine goes away. Where to find that is in the Power button menu, Remote, Ignore. If so, then there are some hardware updates that need to be done on that unit. We can do those here at the Lectrosonics HQ - it would be considered an extended warranty issue.
Breaking into the business... How can I get my feet wet?
karlw replied to Alex T's topic in General Discussion
Alex, I did a series of "wireless side chats" earlier in the year to cover some of the most important concepts in wireless microphone use, including spectrum basics, band planning, frequency coordination, etc. so hopefully the series is useful to you for your background study: https://www.youtube.com/playlist?list=PLwnOnolFSN5K2-2QZOwzVq-0ZFYgoPXDH Knowledge of these fundamentals can really help get you out of a jam when the pressure is mounting, but even before that, you can head off a number of problems before they happen in the first place. And, have a plan B, and a plan C for EVERYTHING. Bring backup batteries, units, cables, memory cards, lav mics, etc. -
Careful frequency choice is your friend. Try to space the channels as far apart as possible within the band, using frequencies from FF as to avoid intermods. If you can position your G2 receivers on the outside of your bag to physically separate them from each other and the SRbs in the bag, that may help a little bit as well. If any of your transmitters have a low power setting, use that - although I think your G2 units are at about 30 mW (actual power 20 mW) and the SMDb units only offer a 50 mW setting. Make sure none of the talent packs have the antennas touching skin or damp undergarments so that the RF isn't totally absorbed.
Hi Jake, I've verified with our programmer that yes, you can mix and match connections via USB and Network on the same running Wireless Designer panel, and the connection lists feature support this as well. With that, yes, you can coordinate all connected devices.
https://www.lectrosonics.com/lectrosonics-introduces-the-dcr-8222-dual-channel-portable-digital-receiver.html
Mattias, I'm not sure what the issue could have been. Could it have been an SRb, which only has a 25.5 MHz tuning bandwidth? So in that case if ch. 1 is in the middle of the band, then Ch. 2 could only be tuned 12 or 13 MHz apart. But an SRc tunes across about 76 MHz. Other than that, I don't know what the issue could have been. Glad to hear you are still getting great results with those classic units!
Constantin, each of the two receiver channels each has two front ends "linked" in Vector Diversity, which is like Ratio Diversity on steroids. But you can link the two sides in Frequency Diversity, for those "absolutely must not fail under any circumstances" situations - it requires two lavs, two transmitters, and two frequencies. Then the 822 becomes 1 receiver on 2 frequencies.
Hi Mattias, as was answered above, the two channels within the 822 can tune independently across the entire available band - the A1B1 version covers 144 MHz, and the B1C1 version covers 155 MHz. But, I'm curious about your comment on the SRc - it also has two independent channels that can tune across the entire band - in that case, an A1 band, B1, band, etc. Or, about 75 Mhz. Hi Jake, it's not possible for WD to have a single saved connection list where a unit (or "frame") has both USB and Network connections. However, it would be easy enough to build and save two connection lists, one with that unit as a USB connection, and one with as a network connection. -Karl
BAB414, pricing will be available on Tuesday from any of our dealers. Cheers!
Day 1 was great - we had a lot of good info & excellent presentations from a wide variety of manufacturers. Day 2 is tomorrow (Friday, Oct. 2) with at completely new set of presentations and discussions. See you there! https://thesoundsummit.org/
Here's a direct link to the Sound Summit if anyone is interested: https://thesoundsummit.org/
Jumping in here - BAB414 - in this small of a package, it just wasn't practical to include Hybrid emulation modes, which would require FM receiver components in the hardware, along with the much larger code space requirements. The larger receivers like DSQD can do this, of course.
It's not much of a surprise at this point... but here are the details! Add this to our ever-expanding digital wireless ecosystem! https://www.lectrosonics.com/Digital-Wireless/product/dchr.html -Karl
- 1 reply
- 2
