Everything posted by fatfatjames
Ya I know...
Your AO1.5X sell me cheap cheap lar.
That is a petrol ps601
Hi, ya does your cr2032 battery work? Sent from my iPad using Tapatalk
I feel that this setup is lighter then my nomad setup. Even though the sd633 is in a heavier bag (ps601) then the nomad (ps614). Maybe also with the sd633 I only put 2 receiver compare to my nomad with 3 receiver.
Sd633 pair up with Wisycom mcr42 and Zaxcom ifb100
Does my method work for anyone who have that problem?
If production wants the file in scene and take number like sd and nomad or maxx... I will continue using wave agent to do that and clock as working hours.
Example your folder is z001 your file names will start from z001001.wav until the end of the day.
I notice that if the antenna is vertical it cause problem, but place horizontal it is ok... And to make sure I place the antenna as far as I can, I place it horizontal in the front pouch of my ps601.
Ok I found that the antenna if you put it horizontal in the front pouch of the sound bag there is no interference.
File naming will always be segnamez000.wav style. They way in work around it is using zaxconvert (which I feel is faster then mirroring, when sometime you forget to switch it on) then use wave agent to change the file name and then generate sound log. Make sure your zaxconvert is the latest. Headphone most likely became on fader 8
Some time yes some time not
I sort of run the stock antenna to the front of my bag via a sma extention cable. Does that count?
Now that i am noticing is that the problem is with my ifb100 s (2.4) it can cause problem with my nomad, fusion, and my sd633... did not notice this before though... Sd633 is the worst...
Portabrace AH-3H Heavy load Harness Redesign.
fatfatjames replied to Adam Butler's topic in Manufacturers & Dealers
Do you think I can just order the belt?- 20 replies
- HarnessPortabrace
- Redesign
Is the waist belt the memory form version?- 20 replies
- HarnessPortabrace
- Redesign
Is there price for this harness?- 20 replies
- HarnessPortabrace
- Redesign
A memory form waist belts will be nice!!
- 152 replies
- ORCA
- Sound Devices 664
(and 5 more)
New arrangement for a new gig...
Hi I did try to ask the pin out configuration of the db25 from wisycom, but have yet got my answer... Does anyone happen to know the pin out configuration? Thanks!!!!
Rich after my present shoot which end in sept I will ship it over to you... Sent from my iPad using Tapatalk
Thanks guys!!! Sent from my iPad using Tapatalk
My wireless keyboard is with on off switch... And switching on and off anytime is not a problem... Sent from my iPad using Tapatalk
